Hi guys,
I just reinstalled my ntb with win8. Before this, I had xbmc 12.3 Frodo installed and everything was OK, but now, after the reinstallation, I can't run any script. Every time I try to run some add-on, it says in the lower right corner: (for example): ERROR: Script failed!: plugin.video.befun.cz ... It's not the problem of befun, because it shows me this error with every addons: (for example): ERROR: Script failed!: plugin.video.twitch.... On my table PC everything is OK and it's working. I hope you guys have any ideas which could help me. THANKS
Do you have the same version of XBMC running on your table PC? There was quite a large number of add-ons that didn't make the Gotham cut. Firewalls can get in the way, router issues & on.. does the Youtube add-on work?
Yes both versions are 12.3 Frodo. Before reinstallation of my windows it was working also on my ntb. Deactivation of firewall didn't help. I have installed McAfee security - I didn't have any antivir before this reinstallation - could this be the problem? Yes youtube add-on works. I have no idea wheres the problem. Any ideas? Thanks for your interest & answer.
I'm not sure why you haven't made the upward step to Gotham, but I suggest you do, it might fix any broken code. The security software could be the culprit (temp disable this) but with the youtube add-on working fine, it points back at the various add-ons and perhaps an internal library update has done more damage than you know. I could go on about add-ons from 3rd party sources and some of the programming rules they break, and how should stick to the official repository add-ons, but I'm sure you know that.
Suggestion: If you're not too deep in Frodo, install the Gotham build as a new install.Delete or rename your program folder, and the roaming folder. Install Gotham as a new build and carefully add the plugins one at a time and ensure their functionality along with the rest of XBMC.
I didn't mention that first XBMC I installed on my ntb after reinstalling my windows was Gotham. However I had this problem so I realized it might be caused because my czech repository is not working with Gotham, so I uninstalled Gotham, found my old Frodo installer in my table PC and installed it on my ntb, but this problem remained. Do I need any "supporting" programs to run XBMC? I'm thinking about if it isn't caused because I don't have any "accompanying" programs installed. I'm sorry for my bad english and I hope you know what I think. I'm not very experienced with XBMC I'm quite a novice here so if you think it is some kind of "expert" problem and I have to change some codes or something like that, I think I'm f***ed. :-D I'm so glad for your tips man.
No XBMC comes ready standalone and works on multiple platforms, while each instance does take advantage of O/S installed routines such as direct X, everything comes in the box ready to go. From what I can deduce, your set-up is fine.... running Youtube as an add-on is the proof of that. You may have lost library overwrites that 3rd party add-ons might alter or arrange differently, so my advice would say to be cautious of the add-ons you install. Use Gotham, it's fully supported now, and pick out the individual add-ons that are no longer responding correctly and address the author of the add-on or forum for the solve. This doesn't look like a XBMC or skin issue at this point.
If you want to pursue this matter further, you will have to supply a proper debug-log pasted to a paste-bin and linked back to this message while encountering the error of which you speak.
Well, I uninstalled Frodo, uninstalled security software, turned off firewall. Then I downloaded Gotham and installed it. Now It says error of version check instantly when I run Gotham, but program runs. I installed Twitch and Youtube add-ons to try if it works. It doesn't. Now on Gotham I can't run anything, nor Youtube which worked on Frodo. I'm so confused about this. Here is my XBMC.log if it could help. There's a second log named XBMC.old.log. If you want it also I can post it here.
14:55:30 T:2088 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:55:30 T:2088 NOTICE: -----------------------------------------------------------------------
14:55:30 T:2088 NOTICE: Starting XBMC (13.0 Git:20140505-f42f5b5). Platform: x86 Win32 32-bit
14:55:30 T:2088 NOTICE: Using Release XBMC x32 build, compiled May 5 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
14:55:30 T:2088 NOTICE: Running on Windows 8 64-bit, build 9200
14:55:30 T:2088 NOTICE: Host CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz, 4 cores available
14:55:30 T:2088 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
14:55:30 T:2088 NOTICE: Running with restricted rights
14:55:30 T:2088 NOTICE: Aero is enabled
14:55:30 T:2088 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
14:55:30 T:2088 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
14:55:30 T:2088 NOTICE: special://masterprofile/ is mapped to: C:\Users\Lubomír\AppData\Roaming\XBMC\userdata
14:55:30 T:2088 NOTICE: special://home/ is mapped to: C:\Users\Lubomír\AppData\Roaming\XBMC\
14:55:30 T:2088 NOTICE: special://temp/ is mapped to: C:\Users\Lubomír\AppData\Roaming\XBMC\cache
14:55:30 T:2088 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
14:55:30 T:2088 NOTICE: Local hostname: yooyooo
14:55:30 T:2088 NOTICE: Log File is located: C:\Users\Lubomír\AppData\Roaming\XBMC\xbmc.log
14:55:30 T:2088 NOTICE: load settings...
14:55:30 T:2088 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:55:30 T:2088 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:55:30 T:2088 NOTICE: Default DVD Player: dvdplayer
14:55:30 T:2088 NOTICE: Default Video Player: dvdplayer
14:55:30 T:2088 NOTICE: Default Audio Player: paplayer
14:55:30 T:2088 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:55:30 T:2088 NOTICE: Log level changed to 0
14:55:30 T:2088 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:55:30 T:2088 NOTICE: Loaded playercorefactory configuration
14:55:30 T:2088 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:55:30 T:2088 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:55:32 T:1340 NOTICE: Thread ActiveAE start, auto delete: false
14:55:32 T:1344 NOTICE: Thread AESink start, auto delete: false
14:55:32 T:1340 NOTICE: Found 2 Lists of Devices
14:55:32 T:1340 NOTICE: Enumerated DIRECTSOUND devices:
14:55:32 T:1340 NOTICE: Device 1
14:55:32 T:1340 NOTICE: m_deviceName : {FB442F29-D06D-4EC0-9588-BDB3B11A1C0D}
14:55:32 T:1340 NOTICE: m_displayName : Speakers - Speakers (Realtek High Definition Audio)
14:55:32 T:1340 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Realtek High Definition Audio)
14:55:32 T:1340 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:55:32 T:1340 NOTICE: m_channels : FL,FR
14:55:32 T:1340 NOTICE: m_sampleRates : 48000
14:55:32 T:1340 NOTICE: m_dataFormats : AE_FMT_FLOAT
14:55:32 T:1340 NOTICE: Device 2
14:55:32 T:1340 NOTICE: m_deviceName : default
14:55:32 T:1340 NOTICE: m_displayName : default
14:55:32 T:1340 NOTICE: Enumerated WASAPI devices:
14:55:32 T:1340 NOTICE: m_displayNameExtra: WASAPI: Speakers (Realtek High Definition Audio)
14:55:32 T:1340 NOTICE: m_sampleRates : 192000,96000,48000,44100
14:55:32 T:1340 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
14:55:32 T:2088 NOTICE: Running database version Addons16
14:55:33 T:2088 NOTICE: ADDONS: Using repository repository.xbmc.org
14:55:33 T:2088 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
14:55:33 T:2752 NOTICE: Thread RemoteControl start, auto delete: false
14:55:33 T:3584 NOTICE: Thread PeripBusCEC start, auto delete: false
14:55:33 T:1944 NOTICE: Thread PeripBusUSB start, auto delete: false
14:55:34 T:1020 NOTICE: Thread JobWorker start, auto delete: true
14:55:34 T:2088 NOTICE: Found screen: Generic PnP Monitor on Intel(R) HD Graphics 3000, adapter 0.
14:55:34 T:2088 NOTICE: Primary mode: 1366x768@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Previous line repeats 2 times.
14:55:34 T:2088 NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1280x600@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
14:55:34 T:2088 NOTICE: Checking resolution 16
14:55:34 T:2088 NOTICE: No Joystick name specified, loading default map
14:55:34 T:2088 NOTICE: Previous line repeats 35 times.
14:55:34 T:2088 NOTICE: Running database version Addons16
14:55:35 T:2088 NOTICE: Running database version ViewModes6
14:55:35 T:2088 NOTICE: Running database version Textures13
14:55:35 T:2088 NOTICE: Running database version MyMusic46
14:55:35 T:2088 NOTICE: Running database version MyVideos78
14:55:35 T:2088 NOTICE: Running database version TV22
14:55:35 T:2088 NOTICE: Running database version Epg7
14:55:35 T:2088 NOTICE: initializing playlistplayer
14:55:35 T:2088 NOTICE: DONE initializing playlistplayer
14:55:36 T:2088 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
14:55:36 T:2088 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:55:36 T:3364 NOTICE: Thread LanguageInvoker start, auto delete: false
14:55:36 T:2088 NOTICE: Previous line repeats 1 times.
14:55:36 T:2088 NOTICE: initialize done
14:55:36 T:972 NOTICE: Thread LanguageInvoker start, auto delete: false
14:55:36 T:2088 NOTICE: Running the application...
14:55:37 T:2088 NOTICE: ES: Starting event server
14:55:37 T:2864 NOTICE: Thread EventServer start, auto delete: false
14:55:37 T:2864 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:55:37 T:704 NOTICE: Thread TCPServer start, auto delete: false
14:55:37 T:2864 NOTICE: UDP: Listening on port 9777
14:55:37 T:3008 NOTICE: Thread RSSReader start, auto delete: false
14:55:38 T:3364 NOTICE: -->Python Interpreter Initialized<--
14:55:39 T:1728 NOTICE: -->Python Interpreter Initialized<--
14:55:39 T:972 NOTICE: -->Python Interpreter Initialized<--
14:55:39 T:3364 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named lib.common
File "C:\Users\Lubom�r\AppData\Roaming\XBMC\addons\service.xbmc.versioncheck\service.py", line 22, in <module>
import lib.common
ImportError: No module named lib.common
14:55:40 T:972 NOTICE: StorageServer Module loaded RUN
14:55:40 T:972 NOTICE: StorageClient-2.5.4 Starting server
14:55:46 T:728 NOTICE: Thread BackgroundLoader start, auto delete: false
14:55:49 T:1564 NOTICE: Thread LanguageInvoker start, auto delete: false
14:55:49 T:1564 NOTICE: -->Python Interpreter Initialized<--
14:55:49 T:1564 NOTICE: Loading cookies from :'C:\\Users\\Lubom\xc3\xadr\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
14:55:49 T:1564 NOTICE: YouTube-4.4.8
14:55:50 T:1564 NOTICE: CommonFunctions-2.5.1
14:55:50 T:1564 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: No module named YouTubeUtils
File "C:\Users\Lubom�r\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py", line 85, in <module>
import YouTubeUtils
ImportError: No module named YouTubeUtils
14:55:50 T:2088 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/
14:55:50 T:2088 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/) failed
14:55:50 T:828 NOTICE: Thread BackgroundLoader start, auto delete: false
14:55:56 T:2088 NOTICE: Storing total System Uptime
14:55:56 T:2088 NOTICE: Saving settings
14:55:56 T:2088 NOTICE: stop all
14:55:56 T:2088 NOTICE: stop player
14:55:56 T:2088 NOTICE: ES: Stopping event server
14:55:57 T:2864 NOTICE: ES: UDP Event server stopped
14:55:57 T:2088 NOTICE: stop sap announcement listener
14:55:57 T:2088 NOTICE: clean cached files!
14:55:57 T:2088 NOTICE: unload skin
14:55:57 T:972 NOTICE: StorageServer-2.5.4 Closed down
14:55:57 T:2088 NOTICE: stopped
14:55:57 T:2088 NOTICE: destroy
14:55:57 T:2088 NOTICE: closing down remote control service
14:55:57 T:2088 NOTICE: unload sections
14:55:57 T:2088 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:55:57 T:2088 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
14:55:57 T:2088 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
14:55:57 T:2088 NOTICE: application stopped...
Please use a proper
pastebin and link back the address attached to a message her. Not many people find these logs interesting, and take a lot of bandwidth for each user who enters the forum. You also need to turn the debugging on in settings>system>debug for the debug log to mean anything. You might want to l
ook over this
I suspect your troubles are an incomplete removal of your old set-up, the usual villain is the roaming folder with the user files.
1) delete or rename C:\Program Files (x86)\XBMC
2) delete or rename C:\Users\PatK\AppData\Roaming\XBMC
A full install of Gotham 13.1 should bring you a fully working XBMC, test it and configure it before you start adding anything. Provide your sources and set-up the scrapers. Cautiously add your add-ons one at a time testing along the way and see which add-on scrambles your set-up. I suggest you stick to add-ons in the official XBMC.org repository.
If this fails, provide a proper debug posted to a paste-bin and linked to this message.
