2014-05-29, 18:36
Hi there,
I am using the Minix Neo X7 Android mediaplayer with XBMC. It works great!
I can remotely control XBMC with the remoteXBMC iOS app and this also works fantastic.
Many thanks XBMC-team!!
But I have the following problem. If I switch off the Minix and a while later on again then sometimes there are
a 'No connection' error because the IP-address on my iPad is no longer valid. This is because the router has given the Minix (and of course XBMC) another dynamic address.
I can setup the router to use static IP addresses. How can I tell Minix to use also a static IP address?
Or is there another possibility to fix this problem?
Many thanks.
Many thanks.
