2014-05-31, 17:34
I am 90% sure this is a directory problem I just cannot figure it out and am hoping someone will have some advice.
The issue is with my TV Shows, which are stored
XBMC Folder
----TV Shows
-------Series
-----------Season
----------------Episode
The (minor but frustrating) problem; Suddenly my TV Show menu button will access the series themselves but none of the episodes. I get the list of series but when I choose one there are no episodes listed. If I choose video from the menu and go into the TV show file then I can access all series and episodes. So I can still access the shows from XBMC I just have to drill down an extra couple of steps. The problem began when I decided to experiment with adding individual folders for each episode, but I only changed one episode of one series when it began.
I have two windows 7 computers with the same problem, one running Gotham the other running the last Frodo they are networked to a 3rd windows 7 computer which stores the media. I was using Aeon Nox but when I began having issues I returned to Confluence to try and troubleshoot.
I have already tried a fresh install on the Gotham computer and various manipulations updates and scrapes of my library.
If anyone can see what I am doing wrong I would appreciate advice.
XBMC Folder
----TV Shows
-------Series
-----------Season
