2014-06-01, 00:20
This is a new box that has just been released. It looks impressive, but the price is a bit steep at $349.
http://www.getxbmc.com/product/xbmc-home-theater-pc/
(2014-06-01, 00:20)Dagger17 Wrote: [ -> ]This is a new box that has just been released. It looks impressive, but the price is a bit steep at $349.
(2014-06-01, 08:50)two515ty Wrote: [ -> ]To be honest, what are we supposed to expect with this box if it's just a standard 1037U unit? It will likely have the same performance of any other unit running a 1037U, with all the major differences coming in hardware setup (if any is even required). For less than $350, you can build your own 1037U mini-ITX box. It might not be as small as this unit, but you can also get the i3 or Baytrail NUC up and running for $350 or less if you want a really small unit. At $350, I'd have to pass on this Prometheus box.
(2014-06-01, 15:01)GortWillSaveUs Wrote: [ -> ](2014-06-01, 08:50)two515ty Wrote: [ -> ]To be honest, what are we supposed to expect with this box if it's just a standard 1037U unit? It will likely have the same performance of any other unit running a 1037U, with all the major differences coming in hardware setup (if any is even required). For less than $350, you can build your own 1037U mini-ITX box. It might not be as small as this unit, but you can also get the i3 or Baytrail NUC up and running for $350 or less if you want a really small unit. At $350, I'd have to pass on this Prometheus box.
+++1
(2014-06-01, 15:30)smwatkin Wrote: [ -> ](2014-06-01, 15:01)GortWillSaveUs Wrote: [ -> ](2014-06-01, 08:50)two515ty Wrote: [ -> ]To be honest, what are we supposed to expect with this box if it's just a standard 1037U unit? It will likely have the same performance of any other unit running a 1037U, with all the major differences coming in hardware setup (if any is even required). For less than $350, you can build your own 1037U mini-ITX box. It might not be as small as this unit, but you can also get the i3 or Baytrail NUC up and running for $350 or less if you want a really small unit. At $350, I'd have to pass on this Prometheus box.
+++1
I feel like the value here is not in the Hardware, it's the reliability of the people behind the release. Hackermil is one of the most dedicated content providers I've seen and has never failed to answer a question. If I were to purchase this box it would be because I KNOW that if anything happens with it or goes wrong I won't be left in the cold with no customer service.
To me that's worth much more than the value of the hardware. Not everybody can or wants to configure/build their own HTPC. This will appeal to the masses.
(2014-06-01, 15:30)smwatkin Wrote: [ -> ]I feel like the value here is not in the Hardware, it's the reliability of the people behind the release. Hackermil is one of the most dedicated content providers I've seen and has never failed to answer a question. If I were to purchase this box it would be because I KNOW that if anything happens with it or goes wrong I won't be left in the cold with no customer service.
(2014-06-01, 19:11)Dagger17 Wrote: [ -> ]I hadn't heard of him before, but see seems like someone trustworthy. They will actually support their product, unlike some other companies.
The only issue I have is that, it loads straight to XMBC. I am not sure how it will work compared to other Android boxes.
(2014-06-01, 19:44)illiac4 Wrote: [ -> ]http://www.aliexpress.com/item/2014-NEW-...34276.html
(2014-06-01, 19:44)MrCrispy Wrote: [ -> ]IMO the value is for people who don't want to build their own and have to setup things. Not everyone has the knowledge or wants to learn how to look for the right components, learn how to put them together, troubleshoot etc. That's worth a lot more than the price difference in hw parts and you still won't get the small case, support etc.
(2014-06-02, 00:02)Ned Scott Wrote: [ -> ]This is a horrible value at $350.
(2014-06-02, 01:22)two515ty Wrote: [ -> ]no it has 4g ram and 16g ssd. Ready to go on openelec.(2014-06-01, 19:44)illiac4 Wrote: [ -> ]http://www.aliexpress.com/item/2014-NEW-...34276.html
For this hardware, this is a much more reasonable price. It looks like you would still have to add your own memory and/or HDD (although you can run OpenELEC from a USB drive), but it won't cost you $350 lol.
