2014-06-02, 17:39
I need your advice, here is the code Discart.
It works well, but when I close and open the window again, he does not go out, it is then necessary to do F5 to resume work. Can you tell me if I made a mistake
Thx very much
Thx very much
PHP Code:
<control type="image">
<left>490</left>
<top>350</top>
<width>200</width>
<height>200</height>
<include>art_Discart</include>
<visible>Skin.HasSetting(discart.movies.enable)</visible>
<visible>Control.IsVisible(594)</visible>
<animation type="WindowOpen">
<effect type="fade" start="0" end="150" time="600" delay="800" tween="sine" easing="out"/>
<effect type="zoom" start="350,450,200,200" end="250,500,200,200" time="980" delay="750" tween="sine" easing="out"/>
<effect type="slide" start="0,0,80" end="80,0,0" time="980" delay="750" tween="sine" easing="out"/>
</animation>
<animation type="WindowClose">
<effect type="fade" start="150" end="0" time="400" delay="200" tween="sine" easing="out"/>
<effect type="zoom" start="250,500,200,200" end="350,450,200,200" time="780" delay="0" tween="sine" easing="out"/>
<effect type="slide" start="80,0,0" end="0,0,80" time="780" delay="0" tween="sine" easing="out"/>
</animation>
</control>
