Full Version: [MYSQL] HOW-TO: 5 User XBMC
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
(2016-01-24, 21:00)horstepipe Wrote: [ -> ]hey BigMong I exactly followed your instructions without SQL errors.
Main-database works, but user-database stays empty.
In Kodi log I have the following error:
19:57:56 T:12264 ERROR: CVideoDatabase::GetMoviesByWhere failed
any ideas?
@horstepipe
What's the databases you are pointing to for the users? in your advancedsettings.xml you need this file for each user/profile
EG:
Main
PHP Code:
<videodatabase>
type>mysql</type>
host>192.168.0.110</host>
port>3306</port>
user>KODI</user>
pass>****</pass>
name>Kodi_Matt_Video_</name>
videodatabase
User
PHP Code:
<videodatabase>
type>mysql</type>
port>3306</port>
user>KODI</user>
pass>****</pass>
name>Kodi_Mace_Video_</name>
videodatabase
The other thing It might be is the files table, you should have a "globalfiles" table under you main user this table will have the cols for each user
then you should have a view "files" and this is maped for all users to the main "globalfiles" table and the right col for each user
if you look in your sql the other users in the view "files" you should see the data for the user. This SQL should give you the data too
PHP Code:
SELECT FROM `Kodi_Mace_Video_93`.`globalfiles
Hope this Helps
Thanks BigMong, just used your 93 instructions and its working perfect.
Awesome, I will look into doing Jarvis and posting the SQL for that setup
(2016-02-24, 10:57)BigMong Wrote: [ -> ]Awesome, I will look into doing Jarvis and posting the SQL for that setup
Looking forward to that.
yeah, me too Big Grin
Ok here is a working setup for Database Version 99 [aka Jarvis]
Sorry for the delay.
My last post for a Database Version 93
This has only been Tested on a New Setup
I would say it will fail the update
I always start fresh with each update, My users Watch Status and Ratings are keeped in https://trakt.tv
Since the database now has user ratings I have created Global Episode,TV Show, and Movie
In my test on the laptop everything is working, I wont be upgrading my home setup yet (Waiting for something)
Please Note: If your Database login is different to KODI you must change it below
PHP Code:
--- PREP ---
  /* GLOBAL FILES */
RENAME TABLE `Kodi_Test_Matt_Video_99`.`filesTO `Kodi_Test_Matt_Video_99`.`globalfiles`;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesCHANGE playCount playCountMatt INT(11);
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesCHANGE lastPlayed lastPlayedMatt TEXT;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD playCountMace INT(11AFTER lastPlayedMatt;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD lastPlayedMace TEXT AFTER playCountMace;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD playCountKiyana INT(11AFTER lastPlayedMace;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD lastPlayedKiyana TEXT AFTER playCountKiyana;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD playCountJaide INT(11AFTER lastPlayedKiyana;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalfilesADD lastPlayedJaide TEXT AFTER playCountJaide;
CREATE VIEW `Kodi_Test_Matt_Video_99`.`files` AS SELECT
`Kodi_Test_Matt_Video_99`.`globalfiles`.`idFile` AS `idFile`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`idPath` AS `idPath`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`strFilename` AS `strFilename`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`playCountMatt` AS `playCount`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`lastPlayedMatt` AS `lastPlayed`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`dateAdded` AS `dateAdded`
FROM `Kodi_Test_Matt_Video_99`.`globalfiles`;
/* GLOBAL EPISODE */
RENAME TABLE `Kodi_Test_Matt_Video_99`.`episodeTO `Kodi_Test_Matt_Video_99`.`globalepisode`;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalepisodeCHANGE userrating userratingMatt INT(11);
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalepisodeADD userratingMace INT(11AFTER userratingMatt;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalepisodeADD userratingKiyana INT(11AFTER userratingMace;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalepisodeADD userratingJaide INT(11AFTER userratingKiyana;
CREATE VIEW `Kodi_Test_Matt_Video_99`.`episode` AS SELECT
`Kodi_Test_Matt_Video_99`.`globalepisode`.`idEpisode` AS `idEpisode`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`idFile` AS `idFile`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c00` AS `c00`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c01` AS `c01`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c02` AS `c02`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c03` AS `c03`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c04` AS `c04`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c05` AS `c05`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c06` AS `c06`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c07` AS `c07`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c08` AS `c08`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c09` AS `c09`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c10` AS `c10`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c11` AS `c11`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c12` AS `c12`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c13` AS `c13`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c14` AS `c14`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c15` AS `c15`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c16` AS `c16`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c17` AS `c17`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c18` AS `c18`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c19` AS `c19`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c20` AS `c20`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c21` AS `c21`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c22` AS `c22`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`c23` AS `c23`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`idShow` AS `idShow`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`userratingMatt` AS `userrating`,
Kodi_Test_Matt_Video_99`.`globalepisode`.`idSeason` AS `idSeason`
FROM `Kodi_Test_Matt_Video_99`.`globalepisode`;
/* GLOBAL TV SHOW */
RENAME TABLE `Kodi_Test_Matt_Video_99`.`tvshowTO `Kodi_Test_Matt_Video_99`.`globaltvshow`;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globaltvshowCHANGE userrating userratingMatt INT(11);
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globaltvshowADD userratingMace INT(11AFTER userratingMatt;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globaltvshowADD userratingKiyana INT(11AFTER userratingMace;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globaltvshowADD userratingJaide INT(11AFTER userratingKiyana;
CREATE VIEW `Kodi_Test_Matt_Video_99`.`tvshow` AS SELECT
`Kodi_Test_Matt_Video_99`.`globaltvshow`.`idShow` AS `idShow`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c00` AS `c00`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c01` AS `c01`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c02` AS `c02`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c03` AS `c03`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c04` AS `c04`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c05` AS `c05`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c06` AS `c06`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c07` AS `c07`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c08` AS `c08`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c09` AS `c09`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c10` AS `c10`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c11` AS `c11`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c12` AS `c12`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c13` AS `c13`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c14` AS `c14`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c15` AS `c15`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c16` AS `c16`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c17` AS `c17`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c18` AS `c18`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c19` AS `c19`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c20` AS `c20`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c21` AS `c21`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c22` AS `c22`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`c23` AS `c23`,
Kodi_Test_Matt_Video_99`.`globaltvshow`.`userratingMatt` AS `userrating`
FROM `Kodi_Test_Matt_Video_99`.`globaltvshow`;
/* GLOBAL MOVIE */
RENAME TABLE `Kodi_Test_Matt_Video_99`.`movieTO `Kodi_Test_Matt_Video_99`.`globalmovie`;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalmovieCHANGE userrating userratingMatt INT(11);
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalmovieADD userratingMace INT(11AFTER userratingMatt;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalmovieADD userratingKiyana INT(11AFTER userratingMace;
ALTER TABLE `Kodi_Test_Matt_Video_99`.`globalmovieADD userratingJaide INT(11AFTER userratingKiyana;
CREATE VIEW `Kodi_Test_Matt_Video_99`.`movie` AS SELECT
`Kodi_Test_Matt_Video_99`.`globalmovie`.`idMovie` AS `idMovie`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`idFile` AS `idFile`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c00` AS `c00`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c01` AS `c01`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c02` AS `c02`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c03` AS `c03`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c04` AS `c04`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c05` AS `c05`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c06` AS `c06`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c07` AS `c07`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c08` AS `c08`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c09` AS `c09`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c10` AS `c10`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c11` AS `c11`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c12` AS `c12`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c13` AS `c13`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c14` AS `c14`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c15` AS `c15`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c16` AS `c16`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c17` AS `c17`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c18` AS `c18`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c19` AS `c19`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c20` AS `c20`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c21` AS `c21`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c22` AS `c22`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`c23` AS `c23`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`idSet` AS `idSet`,
Kodi_Test_Matt_Video_99`.`globalmovie`.`userratingMatt` AS `userrating`
FROM `Kodi_Test_Matt_Video_99`.`globalmovie`;
/* TRIGGER FIX FOR MULT USERS */
DROP TRIGGER IF EXISTS `Kodi_Test_Matt_Video_99`.`delete_file`;
DELIMITER $$
/* REPLACE ---> KODI <--- WITH YOUR MYSQL LOGIN UID FROM THE ADVANCEDSETTINGS.XML */
CREATE DEFINER=`KODI`@`%TRIGGER `Kodi_Test_Matt_Video_99`.`delete_fileAFTER DELETE
  ON
  FOR
EACH ROW
  BEGIN
    DELETE FROM
`Kodi_Test_Matt_Video_99`.bookmark WHERE idfile old.idfile;
DELETE FROM `Kodi_Test_Mace_Video_99`.bookmark WHERE idfile old.idfile;
DELETE FROM `Kodi_Test_Kiyana_Video_99`.bookmark WHERE idfile old.idfile;
DELETE FROM `Kodi_Test_Jaide_Video_99`.bookmark WHERE idfile old.idfile;
DELETE FROM settings WHERE idfile old.idfile;
DELETE FROM stacktimes WHERE idfile old.idfile;
DELETE FROM streamdetails WHERE idfile old.idfile;
END$$
DELIMITER
Here is one user setup, just find and replace to add more.
PHP Code:
--- USER 02 ---
CREATE DATABASE IF NOT EXISTS Kodi_Test_Mace_Video_99 DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci;
/* GLOBAL FILES LINK */
CREATE VIEW `Kodi_Test_Mace_Video_99`.`files` AS SELECT
Kodi_Test_Matt_Video_99`.`globalfiles`.`playCountMace` AS `playCount`,
Kodi_Test_Matt_Video_99`.`globalfiles`.`lastPlayedMace` AS `lastPlayed`,
/* GLOBAL EPISODE LINK */
CREATE VIEW `Kodi_Test_Mace_Video_99`.`episode` AS SELECT
Kodi_Test_Matt_Video_99`.`globalepisode`.`userratingMace` AS `userrating`,
/* GLOBAL TV SHOW LINK */
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tvshow` AS SELECT
Kodi_Test_Matt_Video_99`.`globaltvshow`.`userratingMace` AS `userrating`
/* GLOBAL MOVIE LINK */
CREATE VIEW `Kodi_Test_Mace_Video_99`.`movie` AS SELECT
Kodi_Test_Matt_Video_99`.`globalmovie`.`userratingMace` AS `userrating`
/* USER BOOKMARKS */
CREATE TABLE `Kodi_Test_Mace_Video_99`.`bookmark` (
idBookmarkint(11NOT NULL,
idFileint(11) DEFAULT NULL,
timeInSecondsdouble DEFAULT NULL,
totalTimeInSecondsdouble DEFAULT NULL,
thumbNailImagetext,
playertext,
playerStatetext,
typeint(11) DEFAULT NULL
ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=1;
ALTER TABLE `Kodi_Test_Mace_Video_99`.`bookmarkADD PRIMARY KEY (`idBookmark`), ADD KEY `ix_bookmark` (`idFile`,`type`);
ALTER TABLE `Kodi_Test_Mace_Video_99`.`bookmarkMODIFY `idBookmarkint(11NOT NULL AUTO_INCREMENT;
/* USER VIEWS */
CREATE VIEW `Kodi_Test_Mace_Video_99`.`actor` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`actor`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`actor_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`actor_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`art` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`art`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`country` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`country`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`country_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`country_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`director_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`director_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`genre` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`genre`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`genre_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`genre_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`movielinktvshow` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`movielinktvshow`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`musicvideo` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`musicvideo`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`path` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`path`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`seasons` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`seasons`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`sets` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`sets`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`settings` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`settings`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`stacktimes` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`stacktimes`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`streamdetails` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`streamdetails`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`studio` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`studio`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`studio_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`studio_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tag` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`tag`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tag_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`tag_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tvshowlinkpath` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`tvshowlinkpath`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`version` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`version`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`writer_link` AS SELECT FROM `Kodi_Test_Matt_Video_99`.`writer_link`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`episode_view` AS SELECT
`episode`.`idEpisode` AS `idEpisode`,
episode`.`userrating` AS `userrating`,
episode`.`idSeason` AS `idSeason`,
files`.`strFilename` AS `strFileName`,
path`.`strPath` AS `strPath`,
files`.`playCount` AS `playCount`,
files`.`lastPlayed` AS `lastPlayed`,
files`.`dateAdded` AS `dateAdded`,
tvshow`.`c00` AS `strTitle`,
tvshow`.`c08` AS `genre`,
tvshow`.`c14` AS `studio`,
tvshow`.`c05` AS `premiered`,
tvshow`.`c13` AS `mpaa`,
bookmark`.`timeInSeconds` AS `resumeTimeInSeconds`,
bookmark`.`totalTimeInSeconds` AS `totalTimeInSeconds`
FROM (((((`Kodi_Test_Mace_Video_99`.`episodeJOIN `Kodi_Test_Mace_Video_99`.`filesON((`files`.`idFile` = `episode`.`idFile`)))
JOIN `Kodi_Test_Mace_Video_99`.`tvshowON((`tvshow`.`idShow` = `episode`.`idShow`)))
JOIN `Kodi_Test_Mace_Video_99`.`seasonsON((`seasons`.`idSeason` = `episode`.`idSeason`)))
JOIN `Kodi_Test_Mace_Video_99`.`pathON((`files`.`idPath` = `path`.`idPath`)))
LEFT JOIN `Kodi_Test_Mace_Video_99`.`bookmarkON(((`bookmark`.`idFile` = `episode`.`idFile`) AND (`bookmark`.`type` = 1))));
CREATE VIEW `Kodi_Test_Mace_Video_99`.`movie_view` AS SELECT
`movie`.`idMovie` AS `idMovie`,
movie`.`userrating` AS `userrating`,
sets`.`strSet` AS `strSet`,
sets`.`strOverview` AS `strSetOverview`,
FROM ((((`Kodi_Test_Mace_Video_99`.`movieLEFT JOIN `Kodi_Test_Mace_Video_99`.`setsON((`sets`.`idSet` = `movie`.`idSet`)))
JOIN `Kodi_Test_Mace_Video_99`.`filesON((`files`.`idFile` = `movie`.`idFile`)))
JOIN `Kodi_Test_Mace_Video_99`.`pathON((`path`.`idPath` = `files`.`idPath`)))
LEFT JOIN `Kodi_Test_Mace_Video_99`.`bookmarkON(((`bookmark`.`idFile` = `movie`.`idFile`) AND (`bookmark`.`type` = 1))));
CREATE VIEW `Kodi_Test_Mace_Video_99`.`musicvideo_view` AS SELECT
`musicvideo`.`idMVideo` AS `idMVideo`,
musicvideo`.`idFile` AS `idFile`,
musicvideo`.`c00` AS `c00`,
musicvideo`.`c01` AS `c01`,
musicvideo`.`c02` AS `c02`,
musicvideo`.`c03` AS `c03`,
musicvideo`.`c04` AS `c04`,
musicvideo`.`c05` AS `c05`,
musicvideo`.`c06` AS `c06`,
musicvideo`.`c07` AS `c07`,
musicvideo`.`c08` AS `c08`,
musicvideo`.`c09` AS `c09`,
musicvideo`.`c10` AS `c10`,
musicvideo`.`c11` AS `c11`,
musicvideo`.`c12` AS `c12`,
musicvideo`.`c13` AS `c13`,
musicvideo`.`c14` AS `c14`,
musicvideo`.`c15` AS `c15`,
musicvideo`.`c16` AS `c16`,
musicvideo`.`c17` AS `c17`,
musicvideo`.`c18` AS `c18`,
musicvideo`.`c19` AS `c19`,
musicvideo`.`c20` AS `c20`,
musicvideo`.`c21` AS `c21`,
musicvideo`.`c22` AS `c22`,
musicvideo`.`c23` AS `c23`,
musicvideo`.`userrating` AS `userrating`,
FROM (((`Kodi_Test_Mace_Video_99`.`musicvideoJOIN `Kodi_Test_Mace_Video_99`.`filesON((`files`.`idFile` = `musicvideo`.`idFile`)))
LEFT JOIN `Kodi_Test_Mace_Video_99`.`bookmarkON(((`bookmark`.`idFile` = `musicvideo`.`idFile`) AND (`bookmark`.`type` = 1))));
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tvshowcounts` AS SELECT
`tvshow`.`idShow` AS `idShow`,
MAX(`files`.`lastPlayed`) AS `lastPlayed`,
NULLIF(COUNT(`episode`.`c12`),0) AS `totalCount`,
COUNT(`files`.`playCount`) AS `watchedcount`,
NULLIF(COUNT(DISTINCT `episode`.`c12`),0) AS `totalSeasons`,
MAX(`files`.`dateAdded`) AS `dateAdded`
FROM ((`Kodi_Test_Mace_Video_99`.`tvshowLEFT JOIN `Kodi_Test_Mace_Video_99`.`episodeON((`episode`.`idShow` = `tvshow`.`idShow`)))
LEFT JOIN `Kodi_Test_Mace_Video_99`.`filesON((`files`.`idFile` = `episode`.`idFile`))) GROUP BY `tvshow`.`idShow`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`tvshow_view` AS SELECT
tvshow`.`userrating` AS `userrating`,
path`.`idParentPath` AS `idParentPath`,
tvshowcounts`.`dateAdded` AS `dateAdded`,
tvshowcounts`.`lastPlayed` AS `lastPlayed`,
tvshowcounts`.`totalCount` AS `totalCount`,
tvshowcounts`.`watchedcount` AS `watchedcount`,
tvshowcounts`.`totalSeasons` AS `totalSeasons`
FROM (((`Kodi_Test_Mace_Video_99`.`tvshowLEFT JOIN `Kodi_Test_Mace_Video_99`.`tvshowlinkpathON((`tvshowlinkpath`.`idShow` = `tvshow`.`idShow`)))
LEFT JOIN `Kodi_Test_Mace_Video_99`.`pathON((`path`.`idPath` = `tvshowlinkpath`.`idPath`)))
JOIN `Kodi_Test_Mace_Video_99`.`tvshowcountsON((`tvshow`.`idShow` = `tvshowcounts`.`idShow`))) GROUP BY `tvshow`.`idShow`;
CREATE VIEW `Kodi_Test_Mace_Video_99`.`season_view` AS SELECT
`seasons`.`idSeason` AS `idSeason`,
seasons`.`idShow` AS `idShow`,
seasons`.`season` AS `season`,
seasons`.`name` AS `name`,
tvshow_view`.`strPath` AS `strPath`,
tvshow_view`.`c00` AS `showTitle`,
tvshow_view`.`c01` AS `plot`,
tvshow_view`.`c05` AS `premiered`,
tvshow_view`.`c08` AS `genre`,
tvshow_view`.`c14` AS `studio`,
tvshow_view`.`c13` AS `mpaa`,
COUNT(DISTINCT `episode_view`.`idEpisode`) AS `episodes`,
COUNT(`files`.`playCount`) AS `playCount`,
MIN(`episode_view`.`c05`) AS `aired`
FROM (((`Kodi_Test_Mace_Video_99`.`seasonsJOIN `Kodi_Test_Mace_Video_99`.`tvshow_viewON((`tvshow_view`.`idShow` = `seasons`.`idShow`)))
JOIN `Kodi_Test_Mace_Video_99`.`episode_viewON(((`episode_view`.`idShow` = `seasons`.`idShow`) AND (`episode_view`.`c12` = `seasons`.`season`))))
JOIN `Kodi_Test_Mace_Video_99`.`filesON((`files`.`idFile` = `episode_view`.`idFile`))) GROUP BY `seasons`.`idSeason`;
Find and Repalce Vars:
  • Matt [Count 259]
  • Mace [Count 79]
  • Kiyana
  • Jaide
I use Matt as my main Database, The names above should only match themselves
Opps I left in my Test in the DB names, easy fix Find and Replace "_Test_" with "_" this wont replace anything else
Hey guys,
Thanks for this useful thread!
But I have an error/bug:
05:24:48 17196.566406 T:1967976448   ERROR: GetTvShowsByWhere failed
05:24:48 17196.566406 T:1967976448   ERROR: GetDirectory - Error getting videodb://tvshows/titles/
05:24:48 17196.580078 T:1967976448   ERROR: CGUIMediaWindow::GetDirectory(videodb://tvshows/titles/) failed
05:24:48 17196.634766 T:1427563584  NOTICE: Thread BackgroundLoader start, auto delete: false
05:24:52 17201.093750 T:1419174976  NOTICE: Previous line repeats 1 times.
05:24:52 17201.093750 T:1419174976   ERROR: GetTvShowsByWhere failed
05:24:52 17201.095703 T:1967976448   ERROR: GetDirectory - Error getting library://video/tvshows/titles.xml/
05:24:52 17201.123047 T:1967976448   ERROR: CGUIMediaWindow::GetDirectory(library://video/tvshows/titles.xml/) failed
05:24:52 17201.179688 T:1427563584  NOTICE: Thread BackgroundLoader start, auto delete: false
(2016-03-14, 06:58)nobody1407 Wrote: [ -> ]Hey guys,
Hey nobody1407,
What version are you using? of Kodi and the SQL on this thread?
Thanks for your answer
I collected some informations about MySQL and Kodi
Datenbank-Server
Server: Localhost via UNIX socket
Server-Typ: MySQL
Server-Version: 5.5.44-0+deb8u1 - (Raspbian)
Protokoll-Version: 10
Benutzer: root@localhost
Server-Zeichensatz: UTF-8 Unicode (utf8)
Webserver
nginx/1.6.2
Datenbank-Client Version: libmysql - 5.5.44
PHP-Version: 5.6.17-0+deb8u1
phpMyAdmin
Versionsinformationen: 4.6.0-rc2, aktuelle stabile Version: 4.5.5.1
Kodi
OpenELEC 6.0.3 (kernel: Linux 4.1.18)
Kodi 15.2 Git:02e7013 (Compiled: Mar 1 2016)
I got the solution in your post 104
http://forum.kodi.tv/showthread.php?tid=...pid1902046
Thanks for your support Wink
(2016-03-14, 13:41)nobody1407 Wrote: [ -> ]I got the solution in your post 104
Awesome, was thinking it looked like something I had sorted before Smile
I don't know how you do it BigMong, i tried for the last few weeks and only kept corrupting my DB over and over. Just say the word, Jugs on me!
I just tried your v_99 and it worked right away, Thanks!
I notice you're using a lot more global views... is it only for userrating? is that a new feature of Jarvis? each user can apply their own rating?
Cheers,
(2016-03-14, 21:47)apeg Wrote: [ -> ]I don't know how you do it BigMong, i tried for the last few weeks and only kept corrupting my DB over and over. Just say the word, Jugs on me!
Cheers,
Thank You.
from what I can tell yes, I will have a look into how its used from within Kodi.
I only spent like 15 mins within Kodi testing the rest of the time I was hanging out in phpmyadmin Big Grin
thks for your work......all seems to be right for me and my 4 users.
Big Grin
(2016-03-14, 06:58)BigMong Wrote: [ -> ]Ok here is a working setup for Database Version 99 [aka Jarvis]
PHP Code:
--- PREP ---
  /* GLOBAL FILES */
/* GLOBAL MOVIE */
DELIMITER $$
  ON
  FOR
EACH ROW
  BEGIN
    DELETE FROM
END$$
DELIMITER
PHP Code:
--- USER 02 ---
thumbNailImagetext,
playertext,
playerStatetext,
/* USER VIEWS */
  • Matt [Count 259]
  • Mace [Count 79]
  • Kiyana
  • Jaide
This seems cool, but I have a couple of questions... you say Matt is the main database... but couldn't I just use the word main and then create X number of child databases? What's the advantage?
Also, you say "This has only been Tested on a New Setup"... what do you mean by that?
