Full Version: ConqMOD
Pages: 1 2 3 4
Ok tested it, and it works now. But like you said, it doesn't work when it automatically kicks in (tested both versions).
Also, can I make a suggestion? I think it would look even better if the fanart is blended with the background color. This will make it more consistent with how it's displayed in the library view.
OK will look into that to
updated the download link in the first post with:
-Fanart in Music Now Playing
-Artist slideshow in Musicvisualisation
It looks great! This makes me so happy Smile
Nice mod, makes all the difference to playing music. Is there likely to be a Helix friendly version? I get a dependencies not met error. Thanks.
In time , when i move over to helix i will remake the mod .
Thanks for the info, i shall have to be patient. I would still be on Gotham myself but unfortunately for deinterlaced video to play correctly on my setup i've had to install additional packages that have already moved onto Helix.
For the Helix users of conq
here is the Helix version of my mod
HELIX
Also updated the first post with the download link !
could you post only a diff version of your mod?
Diff version :
HELIX Diff version !!
Hey, nice mod. Thanks for sharing it. May I ask you how (where) to change the time when the music screen kicks in? To better suit my use, I'd like it to pop up a lot sooner. At least 5 seconds (or less.) Thank you very much.
it is easy
in the "IncludesMusicNowPlay2.xml"
change the line :
<visible>Player.HasAudio + System.IdleTime(10)</visible>
in the time you want.
good luck :-)
(2015-01-16, 07:07)monsieurpaulu Wrote: [ -> ]it is easy
change the line :
good luck :-)
Done it. Tried it. Worked.
Thank you again for everything.
hello ,
a little update on the music wallview.
made it a bit bigger
also updated the Diff version and removed Gotham version
This is very cool. Will the "music playing" also work if airplaying to Kodi? I just realized that the original Conq is playing the song fine, but does not display anything (not even a simple coverart). Is this what this MOD is for or any easier way to accomplish just this one feature?
Pages: 1 2 3 4
