Full Version: How to apply kiosk mode to EPG
I'm wondering if this forum would be better suited to my question.
I'd like to modify the EPG in my current skin (aeon mq5) to be placed in kiosk mode.
In other words, when in kiosk mode I don't want any side menu access when pushing the cursor left.
I want it to stop at the end of the lingertime. Is this possible? Confused
Should be possible, but the implementation is totally skin specific.
(2014-06-04, 03:14)Jeroen Wrote: [ -> ]Should be possible, but the implementation is totally skin specific.
Glad to know it may be possible. Any idea which .xml file I should peek into?
No, I think the question would be better suited for Aeon Nox's forum as the way kiosk mode is implemented is completely skin dependant / specific. There is no standard way / XML for it.
Note that this is likely to change in the future, as there is a planned redesign of PVR windows.
