2014-06-04, 22:22
2014-06-04, 22:22
2014-06-06, 15:35
I tried to edit amber's default blue colour in .../colors/defaults.xml
<?xml version="1.0" encoding="UTF-8"?>
<colors>
<color name="Grey3">FF9e9e9e</color>
<color name="Grey2">FFBEBEBE</color>
<color name="Grey">FF5E5E5E</color>
<color name="Label2">FF898989</color>
<color name="Sublist">FF777777</color>
<color name="White">FFCCCCCC</color>
<color name="White2">FFFFFFFF</color>
<color name="Red">FFfe3737</color>
<color name="Blue">FF2261B4</color>
<color name="Black">FF000000</color>
<color name="BlackT">55000000</color>
<color name="BlackST">90000000</color>
<color name="Silver">FFE2E2E2</color>
<color name="Diffuse">FFA0A0A0</color>
<color name="Diffuse2">FF474747</color>
<color name="Disabled">FF5E5E5E</color>
<color name="LiteShadow">35000000</color>
<color name="Shadow">65000000</color>
<color name="ShadowDark">FF262626</color>
<color name="Orange">FFf6b12b</color>
<color name="Orange2">FFeaab01</color>
<color name="Yellow">fff6c42b</color>
</colors>
to <color name="Blue">FFCCCCCC</color>, but after skin reload, mashup looks the same.
I also tried reboot, but with no luck.
Regards.
<colors>
</colors>
Regards.
2014-06-06, 15:42
There's nothing you can do about this (other than modifying the add-on). This is the add-on author abusing / forcing skin formatting in the add-on.
It's incredibly frustrating and stupid.
2014-06-06, 21:12
(2014-06-06, 15:42)Jeroen Wrote: [ -> ]There's nothing you can do about this (other than modifying the add-on). This is the add-on author abusing / forcing skin formatting in the add-on.
I have changed the skin from Amber to Confluence. The color is still blue, but confluence blue is more readable.
Looks like it is property of the skin, isn't it?
2014-06-10, 13:14
So, that is it? Nobody knows?
2014-06-10, 13:15
(2014-06-10, 13:14)kriticar Wrote: [ -> ]So, that is it? Nobody knows?
What question are you expecting an answer to? As I said the add-on author hardcoded these colors into the add-on.
2014-06-11, 11:19
(2014-06-10, 13:15)Jeroen Wrote: [ -> ]What question are you expecting an answer to? As I said the add-on author hardcoded these colors into the add-on.
As the colour is different after changing the skin I believe that this is not property of the addon, so I am expecting to get some details where to look, or what to change in order to test my theory.
