Full Version: Andriod mx box
Hi all I am new to this forum and have just bought an andriod mx box that won't connect to internet says it's connected then in xbmc hardware it say internet busy than says check network setting did not in my wildest imagination think that it would be so much work to get it to work.I am based in Dublin Ireland had xbmc on laptop worked so smooth was great any ideas to solve my problem could it be my internet provider settings on my modem. Thanks in advance hope to here from someone soon
Sounds you might need to do a factory reset and install XBMC from scratch mate unfortunately. If you need me to, I can send you all the files and instructions you will need. One question.....have you tried connecting via both wired and wireless?
