Acording to the wiki there is no simple CH+ CH-.
I'm interested in mapping these to the channel + and - in my PS3 BD remote.
anyone knows how to do it?
Of course there is, either up/down or page up/down if you're using a keyboard, or the same if you use a remote. I suspect your particular remote's keymap doesn't have these triggers though so you need to modify it. Check out the wiki on how to modify your keymap.
(2014-06-06, 18:28)negge Wrote: [ -> ]Of course there is, either up/down or page up/down if you're using a keyboard, or the same if you use a remote. I suspect your particular remote's keymap doesn't have these triggers though so you need to modify it. Check out the wiki on how to modify your keymap.
I just tried with the keyboard, not the remote, and it doesnt go channel plus or minus.
how can I fix it?
Post a
Debug Log where you press those buttons while watching livetv
Just tried it after enabling the debug option, and it worked!
maybe it was some glitch? either way, thanks. I'll post if i find the problem again
Is there a "Last Channel" mapping available? Used to switch between two channels not beside each other.
