On my xbmc 13.1 almost every 5 minutes or less it says scanning TV shows using the tvdb is that normal? There's nothing new and I don't have any autoupdate plugins enabled. What's the deal? Also is there anyway to have it not show the message when its scanning?
It is not normal.
Is it something to do with trakt?
trakt is certainly filling your logs with stuff that makes it difficult reading them. Disable it, do a new debug log and post that.
Ya I saw that...I'm not sure I just have the basic trakt plugin installed. Let me disbase and see what happens. Would uninstalling and reinstalling trakt help?
no just go to addons and disable it. Then start debug mode. Then restart xbmc. Wait for the problem to reproduce, then stop xbmc.
Then
pastebinit .xbmc/temp/xbmc.log
Your log is filled with piracy related addon junk. Might wanna start complaining at those (not here)
Copy that... Sorry, will remove logs
(2014-06-08, 10:12)nickr Wrote: [ -> ]no just go to addons and disable it. Then start debug mode. Then restart xbmc. Wait for the problem to reproduce, then stop xbmc.
Then Code:
OK will do...thanks
