Full Version: Actions on Library in Menus
Could you please add the possibility to add "Update Video Library", "Clean Video Library", "Update Music Library", "Clean Music Library" to the "settings menu" or the "Movies menu" or the "music menu" ?
Those important actions on the Library are a bit burried.
Thanks for your excellent work.
The Update function is available for Video, Movie & Music on the slide out menu The clean function has been discussed many times in the past and is a bit too dangerous for novice users to put at their finger tips, usually a clean isn't needed every time you add something new and the result of a clean of a library when one or more sources are not available can set a bad tone. I like them buried.
