Full Version: remote control !!!!!
please could you help -
i have just purchased an android mx2 fully loaded ( xbmc etc )
the problem i have here in spain is that due to the narrow band width at times due to the world & his wife trying to watch uk tv.
when i try to load any channel ( say bbc1 ) & all i get is continued buffering i cannot with the use of the back button move to another channel
i have to go back to the home screen then reload the channel list & try another channel which is most annoying -( as this then next channel might be buffering as well )- i.e. have to keep re- booting xvmc ( this cannot be write surely
Check what version of XBMC you have. If it is anything less than Gotham 13, un-install it and install Gotham 13.1. Most of those machine pre-loaded with XBMC still come with Frodo or a custom XAF version. Although the XAF can still work correctly in most cases, if it wasn't setup properly with the external players you will have issues.
Gotham is the way to go for most if not all Android.
