Full Version: xbmc not scarping movie folder or file
Hello
I'm having a issue with xbmc not picking up a movie.
folder: The Book Thief (2013)
file: The Book Thief (2013).Blu-Ray Disc.BDRip.ext < its mp4
https://www.themoviedb.org/movie/203833
I have over 700 movie folders and are named in that format. Using tmdb.org to scrape the movies.
I've deleted the folder, uploaded back to the server several times. when I hit scan for new content xbmc does scrape it but doesn't add it to the library correctly...
I also added other movies and they scan perfectly fine.
Kind of clueless why its happening to this movie, I've double checked the spelling, spaces, etc everything is the way it should be.
thank you
If there's only one file with this problem, you could create an nfo file pointing to the themoviedb url as a workaround:
http://wiki.xbmc.org/index.php?title=NFO...ning_a_URL
Debug Log while going to videoinfo on the folder will show you.
Rename your movie without the date
the book thief
instead of
the book thief (2013)
