Full Version: DVDs renamed wrongly [split thread]
Hi I used the renamer function to rename all my movies. It also however renamed all my dvds from
\Movies\Alien (1979)\VIDEO_TS.IFO
to
\Movies\Alien (1979)\Alien (1979).IFO
looks to me this renaming of DVD structure breaks the stacking and file handeling/ scraping in XBMC.
If indeed correct, should this renaming functionality not auto exclude the dvd structure?
seems like I have to rename 800 titles.....any hope....?Sad
DVD file structure XBMC
hmm.. we have an explicitly check to prevent exactly this.
Can you send us the logfile please? (eg via internal bug-reporting)
thx
quick question: did you add the .IFO extension in the settings? (maybe send us your config.xml too in the internal bug report)
Hi - sorry for the delay. The logs / files were just send.
@mlaggner: I did not add any of the DVD extensions (IFO, BUP) in the settings. Config.xml was also send.
thx for looking into this.
cheers
