Full Version: how not have possibility to selectionner toggle !!
hello communauty Wink
I have a small problem, I coded this to enable or disable the background of the menu ( Refocus or Refocus Glass )
Everything works fine, but what I lack is, remove the ability to disable the buttons. !
If you onclick on Menu Refocus Glass, it disables the toggle property to refocus original, but if i disable also button refocus Glass , then it not have nothing on-screen , no visible menu on screen .
Can you help me on this problem. ?
Cheers
into Homemenu.xml
(for code refocus Glass)
<visible>!Skin.HasSetting(homemenuglass.enable)</visible>
and
(for code refocus original
<visible>Skin.HasSetting(homemenurefocus.enable)</visible>
Setting Skin :
PHP Code:
<!--Menu Background -->
control type="radiobutton" id="1009"
label>Refocus Glass Menu</label>
onclick>Skin.ToggleSetting(homemenuglass.enable)</onclick>
onclick condition="Skin.HasSetting(homemenurefocus.enable)">Skin.ToggleSetting(homemenurefocus.enable)</onclick>
selected>!Skin.HasSetting(homemenuglass.enable)</selected>
offclick>Skin.ToggleSetting(homemenurefocus.enable)</offclick>
        <include>
settings_Radiobutton</include>
control
control type="radiobutton" id="1010">
label>Refocus Menu</label>
onclick>Skin.ToggleSetting(homemenurefocus.enable)</onclick>
onclick condition="!Skin.HasSetting(homemenuglass.enable)">Skin.ToggleSetting(homemenuglass.enable)</onclick>
selected>Skin.HasSetting(homemenurefocus.enable)</selected
        <include>
control
<offclick> doesn't exist.
I think what you want is this
PHP Code:
<control type="radiobutton" id="1009">
control
control
Ah a thank you from my heart, to bed at 5 am, and see that it is simple, I m dead . You make me demoralize skinners lol .. I love you Wink ha ha ha !!
I need to understand the logic of the code! Thank you very much Jeroen
Cheers
You're welcome
Just remember togglesetting doesn't change a setting to 1 specific value, it switches between 2 values.
So first time you press the button: A -> B
Second time you press the button: B -> A
Third time... exactly Smile
A + B just being examples to simplify
I will remember!
But now .. I have a new problem whenever I (with your help the communityWink) solved another.
I just create a view, with 4 possible changes, and after have I put your code to change background, the information in this view are no longer visible. I do not understand the link between these two problem, but here I am with a new problem to solve! Hard hard life skiiner! I'm exhausted lol
cheers Smile
