Full Version: movie poster preview broken on "busy" or "recently added" widget view
Aeon MQ5 and Aeon Nox both seem to look at the wrong filename to find a poster to show on the "recently added" widget view
First the screen from Xeebo skin, for reference, showing the movie "12 years a slave".
now the same movie on Aeon MQ5:
and on on Aeon Nox:
Couchpotato is creating cover.jpg and folder.jpg files just fine:
I am using MediaElch to fetch any missing movie info, if needed.
But starting from Gotham, no poster preview is shown at all, so now I need to do it for every single movie!
So I started to compare the created files, by looking at the differences between the files in folders for "working" and "non working" movies.
The only thing extra in the folder for movies that are working properly is a file with the following format: [moviename]-poster.jpg
For reference a screenshot of a movie that is showing properly in the above skin screenshots:
So it seems Aeon MQ5 and Aeon Nox are looking for posters with a different name, then the other skins, which don't seem to have this problem.
Does anybody know how to fix this, so that I don't have to fix my movies manually?
It's a lot of work and really really annoying Smile
