15:40:48 T:11322248 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:40:48 T:11322248 NOTICE: -----------------------------------------------------------------------
15:40:48 T:11322248 NOTICE: Starting XBMC (14.0-ALPHA1 Git:20140610-becbfe4). Platform: Android ARM 32-bit
15:40:48 T:11322248 NOTICE: Using Debug XBMC x32 build
15:40:48 T:11322248 NOTICE: XBMC compiled Jun 10 2014 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
15:40:48 T:11322248 NOTICE: Running on Spreadtrum GOWAY S4 with Android 4.2.2 API level 15, kernel: Linux ARM 32-bit version 3.0.8
15:40:48 T:11322248 NOTICE: FFmpeg version: 2.2.2-xbmc-2.2-Helix-alpha1.1
15:40:48 T:11322248 NOTICE: Host CPU: Quad ARMv7 Processor rev 1 (v7l), 2 cores available
15:40:48 T:11322248 NOTICE: Product: z9_tianxiang, Device: z9_keyingshitong, Board: sp8825eb - Manufacturer: Spreadtrum, Brand: Spreadtrum, Model: GOWAY S4, Hardware: sc8825
15:40:48 T:11322248 NOTICE: ARM Features: Neon enabled
15:40:48 T:11322248 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
15:40:48 T:11322248 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
15:40:48 T:11322248 NOTICE: special://masterprofile/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata
15:40:48 T:11322248 NOTICE: special://home/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc
15:40:48 T:11322248 NOTICE: special://temp/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp
15:40:48 T:11322248 NOTICE: The executable running is: /system/bin/app_process
15:40:48 T:11322248 NOTICE: Local hostname: localhost
15:40:48 T:11322248 NOTICE: Log File is located: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp/xbmc.log
15:40:49 T:11322248 NOTICE: load settings...
15:40:49 T:11322248 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 15
15:40:50 T:11322248 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
15:40:50 T:11322248 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:40:50 T:11322248 WARNING: CSettingInt: unknown options filler "audiocdencoders" of "audiocds.encoder"
15:40:50 T:11322248 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
15:40:50 T:11322248 NOTICE: Found 1 Lists of Devices
15:40:50 T:11322248 NOTICE: Enumerated AUDIOTRACK devices:
15:40:50 T:11322248 NOTICE: Device 1
15:40:50 T:11322248 NOTICE: m_deviceName : AudioTrack
15:40:50 T:11322248 NOTICE: m_displayName : android
15:40:50 T:11322248 NOTICE: m_displayNameExtra: audiotrack
15:40:50 T:11322248 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:40:50 T:11322248 NOTICE: m_channels : FL,FR
15:40:50 T:11322248 NOTICE: m_sampleRates : 44100
15:40:50 T:11322248 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
15:40:50 T:11322248 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:40:50 T:11322248 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:40:50 T:11322248 NOTICE: Default DVD Player: dvdplayer
15:40:50 T:11322248 NOTICE: Default Video Player: dvdplayer
15:40:50 T:11322248 NOTICE: Default Audio Player: paplayer
15:40:50 T:11322248 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:40:50 T:11322248 NOTICE: Log level changed to 0
15:40:50 T:11322248 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:40:50 T:11322248 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
15:40:50 T:11322248 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
15:40:50 T:11322248 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:40:50 T:11322248 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
15:40:50 T:11322248 NOTICE: Loaded playercorefactory configuration
15:40:50 T:11322248 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:40:50 T:11322248 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:40:50 T:11322248 INFO: creating subdirectories
15:40:50 T:11322248 INFO: userdata folder: special://masterprofile/
15:40:50 T:11322248 INFO: recording folder:
15:40:50 T:11322248 INFO: screenshots folder:
15:40:50 T:11322248 INFO: load language info file: special://xbmc/language/Spanish/langinfo.xml
15:40:50 T:11322248 DEBUG: trying to set locale to es_ES.UTF-8
15:40:50 T:11322248 INFO: global locale set to C
15:40:50 T:11322248 INFO: load Spanish language file, from path: special://xbmc/language/
15:40:50 T:11322248 DEBUG: POParser: loaded 3162 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/language/Spanish/strings.po
15:40:50 T:11322248 DEBUG: POParser: id:666 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13441 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13442 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13443 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13444 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13447 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13448 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13449 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:13450 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: id:36394 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
15:40:50 T:11322248 DEBUG: POParser: loaded 52 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/language/English/strings.po
15:40:50 T:12281408 NOTICE: Thread ActiveAE start, auto delete: false
15:40:50 T:12281584 NOTICE: Thread AESink start, auto delete: false
15:40:50 T:12281584 INFO: CActiveAESink::OpenSink - initialize sink
15:40:50 T:12281584 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
15:40:51 T:12281584 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
15:40:51 T:12281584 DEBUG: Output Device : android
15:40:51 T:12281584 DEBUG: Sample Rate : 44100
15:40:51 T:12281584 DEBUG: Sample Format : AE_FMT_S16NE
15:40:51 T:12281584 DEBUG: Channel Count : 2
15:40:51 T:12281584 DEBUG: Channel Layout: FL,FR
15:40:51 T:12281584 DEBUG: Frames : 2560
15:40:51 T:12281584 DEBUG: Frame Samples : 5120
15:40:51 T:12281584 DEBUG: Frame Size : 4
15:40:51 T:11322248 NOTICE: Running database version Addons16
15:40:51 T:11322248 DEBUG: SECTION:LoadDLL(libcpluff-arm.so)
15:40:51 T:11322248 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/libcpluff-arm.so
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/fueradejuego.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Mis Canales.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/PiKoMuLe.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/pluginsxbmc.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Xbmcymas_11052014_deportes.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Xbmcymas_21042014_cultura.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Xbmcymas_21042014_tdt.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Xbmcymas_24042014_series.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 WARNING: CXHandle* CreateFile(LPCTSTR, DWORD, DWORD, LPSECURITY_ATTRIBUTES, DWORD, DWORD, HANDLE), error 20 opening file </mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Xbmcymas_27042014_cine.xml/addon.xml>, flags:800, mode:124.
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.xbmc.org
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.xbmcadult
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.TheYidXXX
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.Dixie-Deans-XBMC-Repo
15:40:52 T:11322248 NOTICE: ADDONS: Using repository plugin.video.xbmctorrent
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.pvr-android.xbmc.org
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.p2p-streams.xbmc
15:40:52 T:11322248 NOTICE: ADDONS: Using repository repository.SportsDevil
15:40:52 T:11322248 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Motorola Nyxboard Hybrid"
15:40:52 T:11322248 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "CEC Adapter"
15:40:52 T:11322248 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Pulse-Eight CEC Adapter"
15:40:52 T:11322248 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "iMON HID device"
15:40:52 T:11322248 DEBUG: PERIPHERALS::CPeripheralBusUSB::CPeripheralBusUSB(PERIPHERALS::CPeripherals*) - using libusb peripheral scanning
15:40:52 T:11322248 DEBUG: SECTION:LoadDLL(libcec.so)
15:40:52 T:11322248 DEBUG: Loading: libcec.so
15:40:52 T:11322248 ERROR: Unable to load libcec.so, reason: Symbol not found:
15:40:52 T:11322248 DEBUG: Dll libcec.so was not found in path
15:40:52 T:11322248 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
15:40:52 T:11985088 NOTICE: Thread PeripBusUSB start, auto delete: false
15:40:52 T:11322248 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
15:40:52 T:11322248 DEBUG: bool CWinSystemEGL::CreateWindow(RESOLUTION_INFO&): Created surface of size 960x540
15:40:52 T:11322248 NOTICE: Current resolution: 960x540 @ 60.00 - Full Screen
15:40:52 T:11322248 NOTICE: Previous line repeats 1 times.
15:40:52 T:11322248 NOTICE: Found resolution 960 x 540 for display 0 with 960 x 540 @ 60.000000 Hz
15:40:52 T:11322248 NOTICE: Found (
[email protected]) at 16, setting to RES_DESKTOP at 16
15:40:52 T:11322248 NOTICE: Checking resolution 16
15:40:52 T:11322248 NOTICE: GL_VENDOR = ARM
15:40:52 T:11322248 NOTICE: GL_RENDERER = Mali-400 MP
15:40:52 T:11322248 NOTICE: GL_VERSION = OpenGL ES 2.0 Spreadtrum Build
15:40:52 T:11322248 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
15:40:52 T:11322248 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
15:40:52 T:11322248 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_EXT_shader_texture_lod
15:40:52 T:11322248 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
15:40:52 T:11322248 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
15:40:52 T:11322248 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
15:40:52 T:11322248 DEBUG: GL: Vertex Shader compilation log:
15:40:52 T:11322248 DEBUG: GL: Vertex Shader compiled successfully
15:40:52 T:11322248 DEBUG: GL: Pixel Shader compilation log:
15:40:52 T:11322248 DEBUG: GL: Fragment Shader compiled successfully
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0xd5c968
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0xd7a9a8
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0xd7bb18
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0xd76090
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0xdb60c8
15:40:52 T:11322248 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0xdb9ad0
15:40:53 T:11322248 DEBUG: GL: Vertex Shader compilation log:
15:40:53 T:11322248 DEBUG: GL: Vertex Shader compiled successfully
15:40:53 T:11322248 DEBUG: GL: Pixel Shader compilation log:
15:40:53 T:11322248 DEBUG: GL: Fragment Shader compiled successfully
15:40:53 T:11322248 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0xdce438
15:40:53 T:11322248 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external YES
15:40:53 T:11322248 DEBUG: GUI Shader [guishader_frag_rgba_oes.glsl]- Initialise successful : 0xdd2f78
15:40:53 T:11322248 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0xdd5e40
15:40:53 T:11322248 NOTICE: Current resolution: 960x540 @ 60.00 - Full Screen
15:40:53 T:11322248 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
15:40:53 T:11322248 INFO: GLES: Maximum texture width: 4096
15:40:53 T:11322248 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
15:40:53 T:11322248 INFO: load default splash image: /data/data/org.xbmc.xbmc/cache/apk/assets/media/Splash.png
15:40:53 T:11322248 INFO: load keymapping
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/joystick.xml
15:40:53 T:11322248 NOTICE: No Joystick name specified, loading default map
15:40:53 T:11322248 NOTICE: Previous line repeats 35 times.
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/mouse.xml
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/remote.xml
15:40:53 T:11322248 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
15:40:53 T:11322248 INFO: Loading special://masterprofile/keymaps/twitter.xml
15:40:53 T:11322248 DEBUG: static uint32_t CButtonTranslator::TranslateKeyboardButton(TiXmlElement*) - invalid key id 0
15:40:53 T:11322248 DEBUG: Previous line repeats 1 times.
15:40:53 T:11322248 INFO: Loading special://profile/keymaps/twitter.xml
15:40:53 T:11322248 INFO: GUI format 960x540, Display 960x540 @ 60.00 - Full Screen
15:40:53 T:11322248 DEBUG: guilib: Fill viewport on change for solving rendering passes
15:40:53 T:11322248 DEBUG: SECTION:LoadDLL(libcurl.so)
15:40:53 T:11322248 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/libcurl.so
15:40:53 T:11322248 NOTICE: Running database version Addons16
15:40:53 T:11322248 DEBUG: void CDatabaseManager::Initialize(bool), updating databases...
15:40:53 T:11322248 NOTICE: Running database version ViewModes6
15:40:53 T:11322248 NOTICE: Running database version Textures13
15:40:53 T:11322248 NOTICE: Running database version MyMusic48
15:40:53 T:11322248 NOTICE: Running database version MyVideos79
15:40:53 T:11322248 NOTICE: Running database version TV24
15:40:53 T:11322248 NOTICE: Running database version Epg7
15:40:53 T:11322248 DEBUG: void CDatabaseManager::Initialize(bool), updating databases... DONE
15:40:53 T:11322248 INFO: DPMS: not supported on this platform
15:40:53 T:11322248 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
15:40:53 T:11322248 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
15:40:53 T:11322248 INFO: Unloading old skin ...
15:40:53 T:11322248 INFO: load skin from: /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence (version: 2.3.0)
15:40:53 T:11322248 INFO: load fonts for skin...
15:40:53 T:11322248 INFO: Loading fonts from /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p/Font.xml
15:40:54 T:11322248 DEBUG: POParser: loaded 148 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/language/Spanish/strings.po
15:40:54 T:11322248 DEBUG: POParser: loaded 0 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/language/English/strings.po
15:40:54 T:11322248 INFO: Loading skin includes from /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p/includes.xml
15:40:55 T:11322248 INFO: load new skin...
15:40:55 T:11322248 INFO: Loading user windows, path /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p
15:40:55 T:11322248 DEBUG: Load Skin XML: 76.32ms
15:40:55 T:11322248 INFO: initialize new skin...
15:40:55 T:11322248 DEBUG: guilib: Fill viewport on change for solving rendering passes
15:40:55 T:11322248 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
15:40:55 T:11322248 DEBUG: Load Pointer.xml: 6.36ms
15:40:55 T:11322248 DEBUG: bool CTextureBundleXBT::OpenBundle() - Opened bundle /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/media/Textures.xbt
15:40:56 T:11322248 DEBUG: Alloc resources: 512.92ms (6.55 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogVolumeBar.xml: 630.14ms
15:40:56 T:11322248 DEBUG: Alloc resources: 734.56ms (630.40 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogKaiToast.xml: 9.77ms
15:40:56 T:11322248 DEBUG: Alloc resources: 12.52ms (12.51 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogMuteBug.xml: 13.31ms
15:40:56 T:11322248 DEBUG: Alloc resources: 13.49ms (13.49 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogSeekBar.xml: 28.16ms
15:40:56 T:11322248 DEBUG: Alloc resources: 30.00ms (28.33 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogBusy.xml: 5.02ms
15:40:56 T:11322248 DEBUG: Alloc resources: 5.24ms (5.19 ms skin load)
15:40:56 T:11322248 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
15:40:56 T:11322248 DEBUG: Load DialogExtendedProgressBar.xml: 5.28ms
15:40:56 T:11322248 DEBUG: Alloc resources: 5.55ms (5.51 ms skin load)
15:40:56 T:11322248 INFO: Loading /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/sounds/sounds.xml
15:40:57 T:11322248 INFO: skin loaded...
15:40:57 T:11322248 DEBUG: JSONRPC: JSON schema type stereoscopicmode references an unknown type GUI.Stereoscopy.Mode
15:40:57 T:11322248 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
15:40:57 T:11322248 INFO: JSONRPC: Adding type "GUI.Property.Value" to list of incomplete definitions (waiting for "GUI.Stereoscopy.Mode")
15:40:57 T:11322248 INFO: JSONRPC: Resolving incomplete types/methods referencing GUI.Stereoscopy.Mode
15:40:57 T:11322248 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
15:40:57 T:11322248 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:40:57 T:11322248 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
15:40:57 T:11322248 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
15:40:57 T:11322248 INFO: JSONRPC v6.16.0: Successfully initialized
15:40:58 T:11322248 DEBUG: ADDON: Starting service addons.
15:40:59 T:19319504 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19319504 INFO: initializing python engine.
15:40:59 T:19544536 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19544536 INFO: initializing python engine.
15:40:59 T:19320752 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19320752 INFO: initializing python engine.
15:40:59 T:19321832 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19321832 INFO: initializing python engine.
15:40:59 T:18334336 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:18334336 NOTICE: Previous line repeats 1 times.
15:40:59 T:18334336 INFO: initializing python engine.
15:40:59 T:11322248 INFO: Previous line repeats 1 times.
15:40:59 T:11322248 DEBUG: Activating window ID: 12999
15:40:59 T:11322248 DEBUG: ------ Window Init (Startup.xml) ------
15:40:59 T:11322248 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
15:40:59 T:19316144 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19316144 INFO: initializing python engine.
15:40:59 T:18331616 NOTICE: Thread JobWorker start, auto delete: true
15:40:59 T:18331616 NOTICE: PVRManager - starting up
15:40:59 T:11322248 DEBUG: Load Startup.xml: 458.28ms
15:40:59 T:11322248 DEBUG: Alloc resources: 458.53ms (458.49 ms skin load)
15:40:59 T:11322248 INFO: removing tempfiles
15:40:59 T:19656584 NOTICE: Thread PVRManager start, auto delete: false
15:40:59 T:19799736 NOTICE: Thread PVRClient start, auto delete: false
15:40:59 T:11322248 NOTICE: void CApplication::UpdateLibraries() - Starting video library startup scan
15:40:59 T:11322248 DEBUG: ADDON: Starting service addons.
15:40:59 T:19636168 NOTICE: Thread VideoInfoScanner start, auto delete: false
15:40:59 T:20028680 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:20028680 INFO: initializing python engine.
15:40:59 T:11322248 NOTICE: initialize done
15:40:59 T:11322248 NOTICE: Running the application...
15:40:59 T:11322248 DEBUG: Activating window ID: 10000
15:40:59 T:20028232 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:20028232 INFO: initializing python engine.
15:40:59 T:19920840 NOTICE: Thread LanguageInvoker start, auto delete: false
15:40:59 T:19920840 INFO: initializing python engine.
15:41:00 T:19636168 NOTICE: VideoInfoScanner: Starting scan ..
15:41:00 T:19636168 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
15:41:00 T:19636168 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
15:41:01 T:19636168 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:01
15:41:01 T:19636168 DEBUG: CAnnouncementManager - Announcement: OnScanFinished from xbmc
15:41:01 T:19636168 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanFinished
15:41:01 T:19636168 DEBUG: Thread VideoInfoScanner 19636168 terminating
15:41:02 T:11322248 INFO: GLES: Enabling VSYNC
15:41:02 T:11322248 INFO: GLES: Selected vsync mode 10
15:41:02 T:11322248 DEBUG: ------ Window Deinit (Startup.xml) ------
15:41:02 T:11322248 DEBUG: ------ Window Init (Home.xml) ------
15:41:02 T:11322248 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
15:41:04 T:11322248 DEBUG: Load Home.xml: 1799.64ms
15:41:05 T:19544536 DEBUG: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py): start processing
15:41:05 T:18334336 DEBUG: CPythonInvoker(4, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): start processing
15:41:05 T:19574736 DEBUG: CPythonInvoker(6, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py): start processing
15:41:05 T:19316144 DEBUG: CPythonInvoker(5, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguidedixie/service.py): start processing
15:41:05 T:20028680 DEBUG: CPythonInvoker(8, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.service.twitter/default.py): start processing
15:41:05 T:19320752 DEBUG: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py): start processing
15:41:05 T:19319504 DEBUG: CPythonInvoker(1, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py): start processing
15:41:05 T:20028232 DEBUG: CPythonInvoker(7, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.service.radiovis/addon.py): start processing
15:41:05 T:19920840 DEBUG: CPythonInvoker(9, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): start processing
15:41:05 T:19321832 DEBUG: CPythonInvoker(3, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): start processing
15:41:05 T:11322248 DEBUG: Alloc resources: 2343.68ms (1806.54 ms skin load)
15:41:05 T:18331616 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
15:41:05 T:11322248 DEBUG: no profile autoexec.py (/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata/autoexec.py) found, skipping
15:41:05 T:11322248 DEBUG: void CNetwork::NetworkMessage(CNetwork::EMESSAGE, int) - Starting network services
15:41:05 T:11322248 NOTICE: starting zeroconf publishing
15:41:05 T:18331616 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
15:41:05 T:11322248 NOTICE: ES: Starting event server
15:41:05 T:11322248 INFO: JSONRPC Server: Successfully initialized
15:41:05 T:11322248 DEBUG: ------ Window Init (DialogOK.xml) ------
15:41:05 T:11322248 INFO: Loading skin file: DialogOK.xml, load type: KEEP_IN_MEMORY
15:41:05 T:20943776 NOTICE: Thread TCPServer start, auto delete: false
15:41:05 T:20943384 NOTICE: Thread JobWorker start, auto delete: true
15:41:05 T:20943384 DEBUG: ZeroconfMDNS: identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:XBMC (localhost) port:9090
15:41:05 T:19909432 NOTICE: Thread EventServer start, auto delete: false
15:41:05 T:19909432 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:41:05 T:19909432 NOTICE: UDP: Listening on port 9777
15:41:05 T:20943384 DEBUG: ZeroconfMDNS: identifier: servers.eventserver type: _xbmc-events._udp name:XBMC (localhost) port:9777
15:41:05 T:20922152 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
15:41:05 T:20922152 DEBUG: ZeroconfEmbedded - processing...
15:41:05 T:18331616 DEBUG: bool CMusicDatabase::GetRecentlyAddedAlbums(VECALBUMS&, unsigned int) query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
15:41:05 T:11322248 DEBUG: Load DialogOK.xml: 15.79ms
15:41:05 T:18331616 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
15:41:05 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 2 ms for 0 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
15:41:05 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 5 ms for 0 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
15:41:05 T:11322248 DEBUG: Alloc resources: 84.15ms (15.99 ms skin load)
15:41:05 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 4 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
15:41:05 T:18331616 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
15:41:05 T:11322248 DEBUG: Checking repositories for updates (triggered by XBMC.org Add-ons)
15:41:05 T:20943384 DEBUG: CFileCache::Open - opening <addons/gotham/addons.xml.md5> using cache
15:41:05 T:20943384 DEBUG: CurlFile::Open(0x14d8110)
http://mirrors.xbmc.org/addons/gotham/a ... ns.xml.md5
15:41:06 T:20943384 INFO: void XCURL:
llLibCurlGlobal::easy_aquire(const char*, const char*, XCURL::CURL_HANDLE**, XCURL::CURLM**) - Created session to
15:41:06 T:18331616 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
15:41:06 T:20780472 NOTICE: Thread JobWorker start, auto delete: true
15:41:06 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 3 ms for 0 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
15:41:06 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 2 ms for 0 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
15:41:06 T:18331616 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 3 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
15:41:06 T:18331616 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
15:41:06 T:20921600 NOTICE: Thread RSSReader start, auto delete: false
15:41:06 T:20921600 DEBUG: CurlFile::Open(0x560cbdb8)
http://feeds.xbmc.org/xbmc
15:41:06 T:20921600 INFO: void XCURL:
15:41:06 T:20922152 DEBUG: ZeroconfMDNS: XBMC (localhost)._xbmc-jsonrpc._tcp.local. registration removed
15:41:06 T:20922152 DEBUG: ZeroconfMDNS: XBMC (localhost)._xbmc-events._udp.local. registration removed
15:41:08 T:20642936 NOTICE: Thread FileCache start, auto delete: false
15:41:08 T:20642936 INFO: CFileCache:
rocess - Hit eof.
15:41:09 T:20642936 DEBUG: Thread FileCache 20642936 terminating
15:41:09 T:20943384 DEBUG: CFileCache::Open - opening <addons/helix/addons.xml.md5> using cache
15:41:09 T:20943384 DEBUG: CurlFile::Open(0x14d8110)
http://mirrors.xbmc.org/addons/helix/ad ... ns.xml.md5
15:41:09 T:19544536 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19544536 DEBUG: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py"
15:41:09 T:19320752 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19320752 DEBUG: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py"
15:41:09 T:19574736 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19574736 DEBUG: CPythonInvoker(6, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py"
15:41:09 T:18334336 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:18334336 DEBUG: CPythonInvoker(4, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py"
15:41:09 T:19544536 DEBUG: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:09 T:19544536 DEBUG: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics
15:41:09 T:19544536 DEBUG: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.cu.lrclyrics/default.py): instantiating addon using automatically obtained id of "script.cu.lrclyrics" dependent on version 2.12.0 of the xbmc.python api
15:41:09 T:20921600 DEBUG: Got rss feed:
15:41:09 T:19321832 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19321832 DEBUG: CPythonInvoker(3, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py"
15:41:09 T:19320752 DEBUG: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:09 T:19320752 DEBUG: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide
15:41:09 T:19319504 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19319504 DEBUG: CPythonInvoker(1, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py"
15:41:09 T:23028448 NOTICE: Thread FileCache start, auto delete: false
15:41:09 T:23028448 INFO: CFileCache:
rocess - Hit eof.
15:41:09 T:19321832 DEBUG: CPythonInvoker(3, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:09 T:19321832 DEBUG: CPythonInvoker(3, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck
15:41:09 T:18334336 DEBUG: CPythonInvoker(4, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:09 T:18334336 DEBUG: CPythonInvoker(4, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader
15:41:09 T:19920840 NOTICE: -->Python Interpreter Initialized<--
15:41:09 T:19920840 DEBUG: CPythonInvoker(9, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py"
15:41:09 T:19320752 DEBUG: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguide/service.py): instantiating addon using automatically obtained id of "script.tvguide" dependent on version 2.1.0 of the xbmc.python api
15:41:09 T:20921600 DEBUG: RSS feed encoding: UTF-8
15:41:09 T:19574736 DEBUG: CPythonInvoker(6, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:09 T:19574736 DEBUG: CPythonInvoker(6, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm
15:41:09 T:20921600 DEBUG: Parsed rss feed:
15:41:09 T:20921600 DEBUG: CurlFile::Open(0x560cbdb8)
http://feeds.xbmc.org/latest_xbmc_addons
15:41:09 T:23028448 DEBUG: Thread FileCache 23028448 terminating
15:41:09 T:20943384 DEBUG: CFileCache::Open - opening <addons/frodo/addons.xml.md5> using cache
http://mirrors.xbmc.org/addons/frodo/ad ... ns.xml.md5
15:41:10 T:20921600 DEBUG: Got rss feed:
15:41:10 T:20921600 DEBUG: RSS feed encoding: UTF-8
15:41:10 T:20921600 DEBUG: Parsed rss feed:
15:41:10 T:20921600 DEBUG: CurlFile::Open(0x560cbdb8)
http://feeds.xbmc.org/updated_xbmc_addons
15:41:10 T:21118024 NOTICE: Thread FileCache start, auto delete: false
15:41:10 T:21118024 INFO: CFileCache:
rocess - Hit eof.
15:41:10 T:20921600 DEBUG: Thread RSSReader 20921600 terminating
15:41:10 T:21118024 DEBUG: Thread FileCache 21118024 terminating
15:41:10 T:20943384 DEBUG: CFileCache::Open - opening <addons/gotham/addons.xml> using cache
15:41:10 T:20943384 DEBUG: CurlFile::Open(0x15ce940)
http://mirrors.xbmc.org/addons/gotham/addons.xml
15:41:10 T:22637896 NOTICE: Thread Timer start, auto delete: false
15:41:10 T:22637896 DEBUG: Thread Timer 22637896 terminating
15:41:10 T:11322248 DEBUG: Unfocus WindowID: 12002, ControlID: 10
15:41:10 T:11322248 DEBUG: Unfocus WindowID: 10000, ControlID: 9000
15:41:10 T:11322248 DEBUG: ------ Window Deinit (DialogOK.xml) ------
15:41:11 T:11322248 DEBUG: Activating window ID: 10040
15:41:11 T:19615968 NOTICE: Thread FileCache start, auto delete: false
15:41:11 T:11322248 DEBUG: ------ Window Deinit (Home.xml) ------
15:41:11 T:19615968 INFO: CFileCache:
rocess - Hit eof.
15:41:12 T:11322248 DEBUG: ------ Window Init (AddonBrowser.xml) ------
15:41:12 T:11322248 INFO: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
15:41:12 T:19574736 DEBUG: CPythonInvoker(6, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.scrobbler.librefm/scrobbler.py): instantiating addon using automatically obtained id of "service.scrobbler.librefm" dependent on version 2.12.0 of the xbmc.python api
15:41:12 T:18334336 DEBUG: CPythonInvoker(4, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): instantiating addon using automatically obtained id of "script.module.simple.downloader" dependent on version 2.1.0 of the xbmc.python api
15:41:12 T:19321832 DEBUG: CPythonInvoker(3, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
15:41:13 T:19615968 DEBUG: Thread FileCache 19615968 terminating
15:41:13 T:11322248 DEBUG: Load AddonBrowser.xml: 1723.43ms
15:41:13 T:20943384 DEBUG: CFileCache::Open - opening <addons/helix/addons.xml> using cache
15:41:13 T:20943384 DEBUG: CurlFile::Open(0x16baf70)
http://mirrors.xbmc.org/addons/helix/addons.xml
15:41:15 T:25288920 NOTICE: Thread FileCache start, auto delete: false
15:41:15 T:25288920 INFO: CFileCache:
rocess - Hit eof.
15:41:15 T:25288920 DEBUG: Thread FileCache 25288920 terminating
15:41:15 T:11322248 DEBUG: Alloc resources: 3705.79ms (1723.67 ms skin load)
15:41:16 T:11322248 DEBUG: CGUIMediaWindow::GetDirectory (addons://disabled/xbmc.pvrclient)
15:41:16 T:11322248 DEBUG: ParentPath = [addons://disabled/xbmc.pvrclient/]
15:41:16 T:20943384 DEBUG: CFileCache::Open - opening <addons/frodo/addons.xml> using cache
15:41:16 T:20943384 DEBUG: CurlFile::Open(0x16baf70)
http://mirrors.xbmc.org/addons/frodo/addons.xml
15:41:16 T:25077472 NOTICE: Thread FileCache start, auto delete: false
15:41:18 T:23155112 NOTICE: Thread BackgroundLoader start, auto delete: false
15:41:18 T:20780472 DEBUG: SECTION:LoadDLL(libImageLib-arm.so)
15:41:18 T:20780472 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/libImageLib-arm.so
15:41:18 T:23155112 DEBUG: Thread BackgroundLoader 23155112 terminating
15:41:18 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.argustv/icon.png' to '3/320cf0da.jpg':
15:41:18 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/3/320cf0da.jpg' size 256x256
15:41:21 T:25077472 INFO: CFileCache:
rocess - Hit eof.
15:41:21 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.dvblink/icon.png' to 'f/f9215abf.jpg':
15:41:21 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/f/f9215abf.jpg' size 256x256
15:41:22 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.dvbviewer/icon.png' to 'd/df2c5dbb.png':
15:41:22 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/d/df2c5dbb.png' size 150x150
15:41:23 T:25077472 DEBUG: Thread FileCache 25077472 terminating
15:41:23 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.mediaportal.tvserver/icon.png' to 'e/e15b61ce.jpg':
15:41:23 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/e/e15b61ce.jpg' size 256x256
15:41:24 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.mythtv.cmyth/icon.png' to '7/728683dc.png':
15:41:24 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/7/728683dc.png' size 256x256
15:41:24 T:31570336 NOTICE: Thread Timer start, auto delete: false
15:41:24 T:31570336 DEBUG: Thread Timer 31570336 terminating
15:41:24 T:11322248 DEBUG: Activating window ID: 10000
15:41:25 T:20780472 DEBUG: Recaching image '/data/data/org.xbmc.xbmc/cache/apk/assets/addons/pvr.nextpvr/icon.png' to 'e/eb4d5c14.png':
15:41:25 T:20780472 DEBUG: cached image 'special://masterprofile/Thumbnails/e/eb4d5c14.png' size 256x256
15:41:25 T:11322248 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
15:41:25 T:11322248 DEBUG: ------ Window Init (Home.xml) ------
15:41:25 T:11322248 DEBUG: Window Home.xml was already loaded
15:41:25 T:11322248 DEBUG: Alloc resources: 53.14m
15:41:25 T:11322248 DEBUG: Unfocus WindowID: 10000, ControlID: 9000
15:41:26 T:19319504 DEBUG: CPythonInvoker(1, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:26 T:19319504 DEBUG: CPythonInvoker(1, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta
15:41:26 T:19316144 NOTICE: -->Python Interpreter Initialized<--
15:41:26 T:19316144 DEBUG: CPythonInvoker(5, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguidedixie/service.py): the source file to load is "/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.tvguidedixie/service.py"
15:41:26 T:19920840 DEBUG: CPythonInvoker(9, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): setting the Python path to /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.chardet/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.pytz/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.buggalo/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.mechanize/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.elementtree/lib:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
15:41:26 T:19920840 DEBUG: CPythonInvoker(9, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): entering source directory /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache
15:41:26 T:19920840 DEBUG: CPythonInvoker(9, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): instantiating addon using automatically obtained id of "script.common.plugin.cache" dependent on version 2.1.0 of the xbmc.python api
15:41:26 T:19319504 DEBUG: CPythonInvoker(1, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.pelisalacarta/library_service.py): instantiating addon using automatically obtained id of "plugin.video.pelisalacarta" dependent on version 2.1.0 of the xbmc.python api
