Full Version: [FEATURE REQUEST] Logoff Button
Hello,
I have noticed that their is no logoff button which is essential for multiple profiles.
Their is a logon screen but no logoff button.
I have attempted to modify the DialogButtonMenu.xml file but cannot get it working reliably.
Any help would be appreciated.
Thank-you.
From memory, there is a 'Switch User' button.
There is if you don't have the Shutdown menu item hidden. I like to press s to bring up the shutdown menu. But also the change user button seems to be flawed. Once i change user I can no longer enter library items on other users other then the first one that I logged in with. I have tested on 2 windows clients. Also it works with confluence and aeon nox.
Try this. I've just modded it for you.
