Somewhere between the 13 and 13.1 release I was no longer able to compile XBMC from source. I was able to compile v13 when it was first released (from the Gotham branch). Then, 13.1 was announced and I decided to not to try the betas/RCs so I have not attempted to compile those. When the final 13.1 version was released, I tried to compile that one, with the same procedure as I've used every time with success. But this time, it didn't work...
I'm failing in the "./configure" step with "could not find a required library". The command terminates with something like:
checking for TAGLIB... yes
checking for CDIO... yes
checking for LIBBLURAY... yes
checking for libbluray soname... libbluray.so.1
checking for bd_register_argb_overlay_proc in -lbluray... no
checking for library containing iconv_open... no
checking for library containing libiconv_open... no
configure: error: Could not find a required library. Please see the README for your platform.
Here's the full config.log file:
http://pastebin.com/nGynLkX6
I'm not sure that's the problem but I manually downloaded, compiled and installed libiconv from
http://www.gnu.org/software/libiconv/, it didn't seem to help though.
In case it's relevant, I always execute the following commands (in that specific order) to compile a new XBMC version:
git clean -xfd
git reset --hard
git pull --rebase
make -C lib/taglib
sudo make -C lib/taglib install
./bootstrap
./configure --disable-debug --disable-pulse --disable-vaapi --enable-goom
make
sudo make install
Thoughts?
Can't nobody help me?
why are you mocking around with taglib, when the error clearly tells you that iconv is the issue?
(2014-06-19, 10:57)ironic_monkey Wrote: [ -> ]why are you mocking around with taglib, when the error clearly tells you that iconv is the issue?
Are you referring to:
make -C lib/taglib
this?
Because that is on the Linux instructions in the XBMC wiki, I just followed them.
Also, I have no idea what iconv is...
(lib)iconv is a library performing charset conversions. it is supplied by pretty much any distro running a gnu userland. you seem to have screwed up your system by building it yourself; the library is mssing the zlib you linked it against. i suggest you remove any trace of the one you built, and use your package manager to install the library. my first suspicion would be a missing -dev package, and that you in fact have the runtime already.
also, any modern distro should supply libbluray for you. iirc debian/ubuntu has since 2009 or thereabout, and they are not exactly the fastest to jump on new and shiny stuff. self-built libraries is really not a good idea if you don't know how these things work (no offense, but you seem a bit nub'y
(2014-06-19, 22:49)ironic_monkey Wrote: [ -> ](lib)iconv is a library performing charset conversions. it is supplied by pretty much any distro running a gnu userland. you seem to have screwed up your system by building it yourself; the library is mssing the zlib you linked it against. i suggest you remove any trace of the one you built, and use your package manager to install the library. my first suspicion would be a missing -dev package, and that you in fact have the runtime already.
I was having this issue before even attempting to build the lib myself, so how can that be the problem?
Ho wcan I debug this and find which -dev package that would be?
i dunno which distro, but search using your package manager. e.g. apt-cache search iconv.
but studying config.log a bit more, this is the cause of your sorrow:
/usr/lib/gcc/x86_64-linux-gnu/4.4.7/../../../x86_64-linux-gnu/libxml2.so: undefined reference to `gzopen64@ZLIB_1.2.3.3'
your libxml2 seems broken. it's not linked to its dependencies (in this case zlib). you could perhaps try
LDFLAGS=-lz ./configure <stuff>
also do a
ldd
/usr/lib/gcc/x86_64-linux-gnu/4.4.7/../../../x86_64-linux-gnu/libxml2.so and pastebin the output.
Here you go:
$ ldd /usr/lib/gcc/x86_64-linux-gnu/4.4.7/../../../x86_64-linux-gnu/libxml2.so
linux-vdso.so.1 (0x00007ffff41ff000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb56e5fb000)
libz.so.1 => /usr/lib/libz.so.1 (0x00007fb56e3e4000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007fb56e1c0000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb56debf000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb56db16000)
/lib64/ld-linux-x86-64.so.2 (0x00007fb56eb71000)
hrmf.
readelf -Ws /usr/lib/libz.so.1 | grep gzopen64
I think I've managed to do it...
Before seeing your latest reply I did a sudo apt-get install zlib1g, which also installed zlib1g-dev. The configure command ran successfully... I'm going to try to compile it now.
I still tried that last command but I got this:
$ readelf -Ws /usr/lib/libz.so.1 | grep gzopen64
readelf: Error: '/usr/lib/libz.so.1': No such file
So I tried this:
$ readelf -Ws /lib/x86_64-linux-gnu/libz.so.1 | grep gzopen64
64: 000000000000d920 13 FUNC GLOBAL DEFAULT 13 gzopen64@@ZLIB_1.2.3.3
that's very weird. your first output shows that it has resolved libz.so.1 as /usr/lib/libz.so.1
could it be a stale ld.so.cache? i.e. sudo ldconfig, ldd again, see if path changed.
Yes, it changed. It probably changed when I upgraded zlib1g.
I'm compiling it right now... I'll report back if I'm successful.
Thanks a lot. I wouldn't know what to do if it weren't for your help
Dammit, didn't work...
I get "undefined reference" to libiconv, libiconv_open and libiconv_close during compilation...
Now I really got it working, hopefully everything is fine...
Just compiled and installed. Ran XBMC, played a video, it seems OK.
What I did was a "make uninstall" on my manually downloaded iconv. That seems to do the trick
