Full Version: Change "Recent Albums" to "Random Albums"
Hoping someone can help me with this...
I am changing the "Recently Added Albums" on the home screen to "Random Albums". I have already changed to the code in IncludesHomeRecentlyAdded so that it pulls random albums with following:
<item>
    <label>$INFO[Window.Property(RandomAlbum.1.Title)]</label>
    <label2>$INFO[Window.Property(RandomAlbum.1.Artist)]</label2>
    <onclick>PlayList.Clear</onclick>
    <onclick>PlayMedia("$INFO[Window.Property(RandomAlbum.1.Path)]")</onclick>
    <icon>-</icon>
    <thumb>$INFO[Window.Property(RandomAlbum.1.Thumb)]</thumb>
    <visible>!IsEmpty(Window.Property(RandomAlbum.1.Title))</visible>
</item>
I simply replaced "Latest" with "Random" in the original code. Everything works fine except that when I click an album, it will not play. Any ideas on how I have to change the code to make it work?
Any thoughts on this inquiry?
You do realise that "Random" is not native to XBMC and that you're using window properties from SkinWidgets
Try using -
<onclick>$INFO[Window(Home).Property(RandomAlbum.1.Play)]</onclick>
It always helps to see how other skins have done it Smile
(2014-06-18, 06:52)Mudislander Wrote: [ -> ]You do realise that "Random" is not native to XBMC and that you're using window properties from SkinWidgets
Try using -
Worked like a charm. Much obliged.
