Full Version: Can the time the VideoOSD stays on before dismissing automatically be changed?
I am using XBMC Gotham with Confluence.
If the user moves the mouse, the VideoOSD will display and then it gets dismissed automatically after a few seconds. I would like to reduce the number of seconds this window is on. Where in the xml files can I control the length of time the VideoOSD stays visible?
Thanks,
No, this is not configurable.
"Not configurable" meaning that it would require a re-build of XBMC?
Correct.
