I've struggled to get help in my other posts about this problem so I've been debugging myself but feel like I've exhausted my knowledge. The log is here
http://xbmclogs.com/show.php?id=229030 and the freeze occurs around the 20:04 mark in the log.
You need to post a full log, not a partial one. You also need to turn on debug logging in Settings-System-Debug
Debugging is turned on in this log and the freeze happened between those times, it's not partial. If you want a full log fine but I'll need to post later when it happens again as I've lost that day due to having to restart XBMC to solve the issue.
Thanks for replying, appreciate it.
The full log is needed. Can't tell what you are playing and what the conditions are while you are playing it. It also helps to see what devices are initialized.
