2014-06-20, 13:17
2014-06-20, 16:02
explain your setup a little more please. ie amount of tuners/satellites. what switches you have and in what order. it will be easier to explain once we know
2014-06-21, 00:03
I have a zenwell 22khz switch. I have dishnetwork. Sat 119/110 on my satellite reciver I can use that switch to switch between sat. Because my 119 is on 22khz on and my 110 is on 22khz off
2014-06-21, 06:13
ok
1. you'll need to choose advance in the satconf.
2. choose 2 orbital positions
3. in each satellite choose generic for switch
i'm not sure which is off and which is on so you may need do some trial an error so maybe only plug on sat into
4. in switch config choose tone burst A in 1 B in the other.
5. add in your networks in the networks tab
6. put the correct network in each orbital position and your system should scan both.
