I' ve done the Linux installation of my HTPC from this HOWTO
(Linux - vaapi-sse4: Deinterlacing Testing)
After that I tried to start a standalone Game (UlraStar-deluxe) via Advaned Launcher but it fails...
I allways got the following Error
UltraStar Deluxe V 1.1.0 Build Error Log
Date: 18-6-14 Time: 16:52:14
ERROR: Initialize failed, Removing - SDL_Playback
So I thought there is a problem with the Windowmanager and I installed kde-plasma-desktop.
After this the HTPC boots into the KDE-login screen.
When I start the xbmc-session everything fine works with the game..
So my question is, must I install the whole kde-plasma-desktop or is there a other better way
now I'm realy caonfused.
I build up a second VM on a AMD computer. and followed the HowTo "Linux - Radeon OSS with vdpau"
And tried there to start the Gaame from Advacend Launcher and it works!
If I see it right ist the same upstart-script as for "Linux - vaapi-sse4: Deinterlacing Testing.
So i think it has nothing to to with KDE...
Can anybody explain me why it doesent work on my i3 HSW?
not shur if its importent but I found the following issue in /var/log/upstart/xbmc.log
X.Org X Server 1.15.1
Release Date: 2014-04-13
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
Current Operating System: Linux mediacenter 3.13.0-29-generic #53-Ubuntu SMP Wed Jun 4 21:00:20 UTC 2014 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-29-generic root=UUID=5784d2e2-37bf-4864-9f37-9ea6c923694f ro splash quiet vt.handoff=7
Build Date: 16 April 2014 01:36:29PM
xorg-server 2:1.15.1-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 20 06:31:30 2014
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
setversion 1.4 failed: Permission denied
the last line
maybe that could be the reason? ans how could I solve that?
so, that was not the problem...
I tried this
xinit /usr/bin/ufo -- :1 vt1
to fix it but it dosent change anything...
It seems that a second xsession is running but not right or without focus...
here ist the
debug-log
so I've no more ideas... I know to less about linux...
After some more test I guess I've a problem with the OpenGl Driver...
As I wrote above I tried to start a "little simple old" game via Advanced Launcher with no
success on my i3 HSW.
So I installed two virtuell machines on two different Workstations.
The 1st is a i5 IVB and the 2nd is a A8-5500... on both VM the game
running without any Problems...
After this I installed XBMCbuntu on a USB-Stick and tried again without success...
So If I compaire the different systems tha main different is in the OpenGL Driver.
The Virtuell Machine use his own emulated Grafik-driver... so I thougt that should be
the problem... but how could I solve it...
So tried to find some info on google but the only info I found was to create a xorg.conf but
I'm not shure that will solve my problem...
I've found another xbmc.log in /var/log/upstart/xbmc.log
this is the log after I start xbmc:
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 25 20:12:44 2014
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Running DIL (3.22.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
and this appears when I start the program
An unhandled exception occurred at $000000000044822E :
EAccessViolation : Access violation
$000000000044822E
$00000000004D71DC
$00000000004C9EA6
$000000000047250B
any ideas...?
Have you try to use a small script that will close XBMC prior to start ultrastar ?
#!/bin/bash
killall -9 xbmc.bin
/usr/bin/ultrastardx
xbmc
(2014-06-26, 12:42)Angelscry Wrote: [ -> ]Have you try to use a small script that will close XBMC prior to start ultrastar ?
#!/bin/bash
killall -9 xbmc.bin
xbmc
No, I don't have because I don't know how to use...
But I searched for the Error.Log Massage in the Surcecode.
And I found the following...
// find and initialize playback interface
DefaultAudioPlayback := nil;
FilterInterfaceList(IAudioPlayback, MediaManager, InterfaceList);
for i := 0 to InterfaceList.Count-1 do
begin
CurrentAudioPlayback := InterfaceList[i] as IAudioPlayback;
if (CurrentAudioPlayback.InitializePlayback()) then
begin
DefaultAudioPlayback := CurrentAudioPlayback;
break;
end;
Log.LogError('Initialize failed, Removing - '+ CurrentAudioPlayback.GetName);
MediaManager.Remove(CurrentAudioPlayback);
end;
and
this....
#!/bin/bash
killall -9 xbmc.bin
xbmc
that will not work for me because I start xbmc with the startup-script frome
here.
so I've to stop xbmc as follow...
sudo service xbmc stop
So I include this line in the your script but I allways have to put in the sudo password...
(2014-06-27, 13:44)sveni_lee Wrote: [ -> ] (2014-06-26, 12:42)Angelscry Wrote: [ -> ]Have you try to use a small script that will close XBMC prior to start ultrastar ?
#!/bin/bash
killall -9 xbmc.bin
xbmc
that will not work for me because I start xbmc with the startup-script frome here.
Why you need to start XBMC as a service?
(2014-06-27, 15:23)Angelscry Wrote: [ -> ]Why you need to start XBMC as a service?
It' the only way to start and stop xbmc....
If I try
It allways starts immediately start again...
(2014-06-27, 15:45)sveni_lee Wrote: [ -> ] (2014-06-27, 15:23)Angelscry Wrote: [ -> ]Why you need to start XBMC as a service?
If I try
No, no, no... That's the only way to not be able to close it. As you write it, killing XBMC make it always start again and again. So you cannot close it. Another way to start XBMC would be to simply start it as user using the command :
But it seems that the way you have choosen to install XBMC (
http://forum.xbmc.org/showthread.php?tid...pid1429454) is really complicated.
(2014-06-27, 16:00)Angelscry Wrote: [ -> ]No, no, no... That's the only way to not be able to close it. As you write it, killing XBMC make it always start again and again. So you cannot close it. Another way to start XBMC would be to simply start it as user using the command :
But it seems that the way you have choosen to install XBMC (http://forum.xbmc.org/showthread.php?tid...pid1429454) is really complicated.
yes, thats true...
but if I choose the virtuell console and I try
as root it works... the game starts
but i have a sound problem... I can't hear anything...
xbmc stop/waiting
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 27 16:21:11 2014
ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm_dsnoop.c:618:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Zugriff verweigert
Cannot connect to server socket err = Datei oder Verzeichnis nicht gefunden
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
Have you pulse audio installed on your system?
no, i need alsa as you can see in @
fritsch : Howto...
