Full Version: Xbox Controller Keymaps - Xbox One + Xbox 360
Hello all i just wanted to share with you my Xbox keymaps that i have created.
There are 2 versions of the keymap, one is for the Xbox 360 Controller and the other is for the Xbox One Controller.
The keymap should work with any Xbox controller because of the large list of altnames.
I have tested this out with an Xbox 360 Wired Controller, Xbox 360 Wireless Controller and an Xbox One Controller and all of them worked perfectly.
Tested on XBMC Eden, Frodo and Gotham.
Here is the key layout :
Left - Left
Right - Right
Up - Up
Down - Down
Right Stick Up - Volume Up
Right Stick Down - Volume Down
A - Enter
B - Back
Y - Eject
X - Maximize/Minimize
Start - PlayerControls/Menu
Back - Power options
LB - Context Menu
RB - Nothing
Triggers - Scroll left/right
And here are the download links :
Xbox 360 Controller Keymap
Xbox One Controller Keymap
I've created a native solution. I made a keymap .XML file that can be put into the Kodi folder that makes the Xbox One Wireless Controller used through the Xbox Wireless Adapter work correctly. This solution is just version 1.0, as it has not been optimized fully. Once it has been, the Kodi team can implement it into their app so everyone can have it working effortlessly.
See solution here: Reddit Post
