2014-06-22, 02:56
I have recently started developing a new skin called Lucid. The interface was designed by someone called fwdpxl and was originally just a concept for the Xbox One.
This skin based around my Xbox One skin and is very minimal. Nearly everything from my Xbox skin has been removed and i have now got the skin size down to 12mb!
There are no requirements or anything as well!
There is an early test version available for download from here : Mediafire
More views will be added in to the next update. To change the views, go to skin settings - random - enable appbar. Then go to views and enable the ones you want.
To switch views while in the library, just press down to access the appbar and pick a view. (Appbar must be enabled + selected view)
(Video is really laggy abecause of poor software)
Here is how this skin is currently looking :
If you like this skin and you feel that you would like to help out a little bit then you can donate here :
watch gallery
