Full Version: lower the menu bar in home screen and increase picture size
hi there all,
I'm running xbmc gotham on linux with the confluence skin. I prefer this skin still over the others available. I'm using a 65 inch tv and noticed that some little adjustments to the skin would be great.
Mainly I'd like to lower the menu bar (with weather, pictures, videos, movies, tv shows, music etc.) to almost reach the bottom, then I'd like to increase the size of the displayed screenshots from my Movies or TV shows library in the main screen (as there is more space now due to lowered menu bar).
I looked around to find a solution:
http://forum.xbmc.org/showthread.php?tid=162498
http://forum.xbmc.org/showthread.php?tid=175933
http://forum.xbmc.org/showthread.php?tid...pid1394397
but there are no "posy" entries anymore in any of the xml files.
How can I accomplish this?
In Gotham there is a new control positioning method. The <posy> and <posx> have been replaced with <left>, <top> etc but they should work in the same way.
(2014-06-24, 00:02)Arzk Wrote: [ -> ]In Gotham there is a new control positioning method. The <posy> and <posx> have been replaced with <left>, <top> etc but they should work in the same way.
great, will check it out, thanks! Smile
