2014-06-24, 06:02
did some searching but couldn't find much and hope someone can help!
I have multiple XBMC devices w/ mySQL db in my house and they all use Aeon MQ 5 skin. (it's amazing BTW!)
My issue is: I use 1 HTPC to do all the scanning for the libraries and that HTPC updates the recently added widget, when a scan is complete, as it should.
However the other devices never "refresh" the recently added widget. The only way I can get the skin to update is to reboot the device or run an update library (which it finds nothing because the db already has been updated.
My question is, is there a script, command, or setting I can use to force my other devices to update the recently added lists? (I tried to ReloadSkin() command and it did not work)
Any ideas?
Any ideas?
