PHP Code:
<visible>!Control.IsVisible(50)| !Control.IsVisible(51) | !Control.IsVisible(52)| !Control.IsVisible(521) | !Control.IsVisible(522)| !Control.IsVisible(53) | !Control.IsVisible(531)| !Control.IsVisible(532) | !Control.IsVisible(54)| !Control.IsVisible(57) | !Control.IsVisible(571)| !Control.IsVisible(572) | !Control.IsVisible(573)| !Control.IsVisible(574) | !Control.IsVisible(575)| !Control.IsVisible(576) | !Control.IsVisible(58)| !Control.IsVisible(581) | !Control.IsVisible(59)| !Control.IsVisible(591) | !Control.IsVisible(592)| !Control.IsVisible(593) | !Control.IsVisible(594)| !Control.IsVisible(595) | !Control.IsVisible(596)| !Control.IsVisible(597) | !Control.IsVisible(60)| !Control.IsVisible(61) | !Control.IsVisible(62)| !Control.IsVisible(63) | !Control.IsVisible(631)| !Control.IsVisible(632) | !Control.IsVisible(633)</visible>
</control>
Hello all !!
Is it possible to have a few things shorter than that?
thx
I want to hide the button on all views. is that there are few things more short?
When do you want to show it?
I do not want to show, I want to hide it an option (2 toggle = 1 only displayed)
And it must be hidden in all views! Never displayed, but must work when another toggle is off
So if I understand correctly you want to show it when a setting is enabled and when it's disabled you don't want to show it?
no! this is not it!
2 buttons: one by default, and an option (do not display the toggle by default in contectuel menu) and displayed only extra option!
PHP Code:
<control type="radiobutton" id="508">
<label>Landscape</label>
<onclick>Skin.ToggleSetting(landscape.enable)</onclick>
<onclick>Skin.ToggleSetting(thumb.enable)</onclick>
<selected>!Skin.HasSetting(landscape.enable)</selected>
<visible> ----- ???? Hide all views -----</visible>
<include>menu_Button</include>
<include>menu_RadioButton</include>
</control>
<control type="radiobutton" id="509">
<label>Extra Thumb</label>
<selected>Skin.HasSetting(thumb.enable)</selected>
<visible>Control.IsVisible(593)</visible>
</control>
Sorry but I don't get it. Maybe someone else knows what you're trying to achieve.
ok:
I would like to hide a toggle only ( 2 toggle / 1 hide ) , but it remains active, if the other is turn off! Possible or not?
Try <visible>!Skin.HasSetting(thumb.enable)</visible>
This will display your first button (508) only if the second radiobutton (509) is off.
Whatever is between the <selected> tags is what you use in a visibility condition.
Edit:I think I misunderstood what you wanted. If you want to hide it no matter what, use <visible>no</visible>. The button remains active, but it won't be displayed.
YES !!!!!!!!!!!!!!!!!!!!!! Thx !! thx thx !!
it s good !
Thx Amelandbor for you help , sorry , my english is very very very bad ;(
it is good! I needed two methods! And you answered the two methods! sorry for my bad english! Thank you both for trying despite this, to help me!
