2014-06-29, 08:17
Hi all,
just a quick info for skins that have RCB support and that make use of RCBs internal string ids: I had to do some changes to the string ids. All string ids have been moved to a range between 32000 and 32999. Right now RCB ships the old and the new ids together, so it will remain backward compatible for a while. But in future please make sure only to use the new ids.
If you did not mix up RCBs ids with your own ones in the same range, it should be save to make these replacements in your RCB skin files (order is important):
Thanks,
malte
id="350 -> id="320
id="400 -> id="321
id="401 -> id="322
id="450 -> id="323
id="500 -> id="324
id="510 -> id="325
id="520 -> id="326
id="530 -> id="327
id="5400 -> id="3275
id="5500 -> id="3280
id="5600 -> id="3285
id="5700 -> id="3290
id="30000 -> id="32999
Thanks,
malte
