.. recently I use F.T.V add-on, noticed there's a horror channel .. I believe it is a UK free-to-air tv channel, now as I remember Movies4Men 1&2 is also FTA, but F.T.V doesn't have it, is there any other add-on with Movies4Men?
thanks!
I think the TVCatchup addon has this if I remember correctly. You'll need to be UK based to view the channels this app shows though...basically it's UK freeview
.. yes, TVCatchup have it, but it is not available to me .. any other solution?
thanks!
Can you connect to the net via a vpn then run tv catchup?
.. well, maybe .. any specific vpn?, since TVCatchup is known as very well protected .. but, I believe it would be complicated, since I run xbmc over minix neo g4 ..
thanks!
