Full Version: "Startup Window -> TV" don't work anymore on Gotham 13.1
I have already posted this Issue on OE Forums: http://openelec.tv/forum/72-xbmc/71791-s...frodooe3-0
But since this Bug is persistent on Windows too, i think this is an General XBMC Bug, not an OpenElec.
Also it don't depends on VDR, it is a Generally PVR/XBMC Bug.
In Frodo and OE3.0 it worked for me, since i updated to OE4.0 and Gotham, it won't work any more.
-> http://abload.de/img/screenshot000xojpl.png
OpenElec Logs: http://goo.gl/PjgvGw
Windows Logs: http://xbmclogs.com/show.php?id=237559
By the Way, why it is called Minimised here: http://abload.de/img/screenshot002j3jxe.png ?
When i activate this, then i get an LiveTV Picture in the Background.
Would it be better to name it Background, instead of Minimised?
(2014-06-30, 09:22)-DDD- Wrote: [ -> ]I have already posted this Issue on OE Forums: http://openelec.tv/forum/72-xbmc/71791-s...frodooe3-0
it would be nice if you could open a trac issue on http://trac.xbmc.org
(2014-06-30, 09:22)-DDD- Wrote: [ -> ]By the Way, why it is called Minimised here: http://abload.de/img/screenshot002j3jxe.png ?
it should indicates that it will not playback in foreground. i agree, we should change it to "off", "foreground", "background".
Thanks, i created a ticket http://trac.xbmc.org/ticket/15321
Minimised is that for me: http://attachments.team-mediaportal.com/...hot001.jpg
Should i also create an extra Ticket for the Renaming of the Minimised -> Background?
(2014-06-30, 11:12)-DDD- Wrote: [ -> ]Thanks, i created a ticket http://trac.xbmc.org/ticket/15321
(2014-06-30, 11:12)-DDD- Wrote: [ -> ]Minimised is that for me: http://attachments.team-mediaportal.com/...hot001.jpg
No because it's not a bug and we handle improvement/feature requests in our forum.
I've looked into detail and think we should change the current settings implementation for this option too.
I'll open a Pull-Request for that soon.
for the label changes I opened up a PR https://github.com/xbmc/xbmc/pull/4969
Remains this feature broken for Gotham 13.2 ?
If so, wouldn´t it be better to remove it (at least the visible gui part) till someone fix it or is a broken feature better than no feature ? Wink
