2014-06-30, 14:53
Hi all!
Fresh install of XBMC 13.1 on Ubuntu 14.04LTS. I installed two addons from xbmchub.com (Addon Installer and Config Manager) and one from the official XBMC repo (YouTube) and all three addons show the same behavior.
The install fine but when i want to launch them i get the Working dialog and nothing else. Using ESC i can cancel them and XBMC seems to work correctly.
Last lines in the log are:
12:25:15 T:3031893824 DEBUG: OnKey: return (0xf00d) pressed, action is Select
12:25:15 T:3031893824 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.program.addoninstaller/)
12:25:15 T:3031893824 DEBUG: ParentPath = [addons://sources/executable/]
12:25:15 T:2805979968 DEBUG: StartScript - calling plugin Addon Installer('plugin://plugin.program.addoninstaller/','1','')
12:25:15 T:2805979968 DEBUG: WaitOnScriptResult - waiting on the Addon Installer (id=2) plugin...
12:25:15 T:2755603264 NOTICE: Thread LanguageInvoker start, auto delete: false
12:25:15 T:2755603264 INFO: initializing python engine.
12:25:15 T:2755603264 DEBUG: CPythonInvoker(2, /home/ton/.xbmc/addons/plugin.program.addoninstaller/default.py): start processing
12:25:16 T:3031893824 DEBUG: ------ Window Init (DialogBusy.xml) ------
Any ideas?
Any ideas?
