Full Version: tinyMediaManagerCMD not working
can someone tell me why my cmd not working i use this i my .bat file "C:/Users/My Username/AppData/Roaming/tinyMediaManager/tinyMediaManagerCMD.exe" -update -renameNew -scrapeNew
2014-06-30 21:52:43,390 INFO  [main] org.tinymediamanager.TinyMediaManager:212 - =====================================================
2014-06-30 21:52:43,394 INFO  [main] org.tinymediamanager.TinyMediaManager:213 - === tinyMediaManager (c) 2012-2013 Manuel Laggner ===
2014-06-30 21:52:43,395 INFO  [main] org.tinymediamanager.TinyMediaManager:214 - =====================================================
2014-06-30 21:52:43,396 INFO  [main] org.tinymediamanager.TinyMediaManager:215 - tmm.version      : 2.5.5 (r1407)
2014-06-30 21:52:43,621 INFO  [main] org.tinymediamanager.TinyMediaManager:221 - os.name          : Windows 8.1
2014-06-30 21:52:43,621 INFO  [main] org.tinymediamanager.TinyMediaManager:222 - os.version       : 6.3
2014-06-30 21:52:43,621 INFO  [main] org.tinymediamanager.TinyMediaManager:223 - os.arch          : amd64
2014-06-30 21:52:43,621 INFO  [main] org.tinymediamanager.TinyMediaManager:224 - java.version     : 1.7.0_60
2014-06-30 21:52:43,623 WARN  [main] org.tinymediamanager.ui.TmmUIHelper:54 - cannot open init filedialogorg.eclipse.swt.widgets.FileDialog
2014-06-30 21:52:43,623 INFO  [main] org.tinymediamanager.TinyMediaManager:666 - default encoding : Cp1252 | Cp1252 | windows-1252
2014-06-30 21:52:43,624 INFO  [main] org.tinymediamanager.TinyMediaManager:666 - set encoding to  : UTF-8 | UTF8 | UTF-8
2014-06-30 21:52:43,650 INFO  [main] org.tinymediamanager.TinyMediaManager:254 - System language  : da_DK
2014-06-30 21:52:43,651 INFO  [main] org.tinymediamanager.TinyMediaManager:255 - GUI language     : da_DK
2014-06-30 21:52:43,651 INFO  [main] org.tinymediamanager.TinyMediaManager:256 - Scraper language : English
2014-06-30 21:52:43,651 INFO  [main] org.tinymediamanager.TinyMediaManager:257 - TV Scraper lang  : English
2014-06-30 21:52:43,653 DEBUG [headless] org.tinymediamanager.TinyMediaManager:270 - starting without GUI...
2014-06-30 21:52:43,661 DEBUG [headless] org.tinymediamanager.TinyMediaManager:314 - no splash found
2014-06-30 21:52:43,661 INFO  [headless] org.tinymediamanager.TinyMediaManager:323 - =====================================================
2014-06-30 21:52:43,662 INFO  [headless] org.tinymediamanager.TinyMediaManager:324 - starting tinyMediaManager
2014-06-30 21:52:43,662 DEBUG [headless] org.tinymediamanager.TinyMediaManager:345 - Loading native mediainfo lib from: native/windows-amd64
2014-06-30 21:52:43,697 INFO  [headless] org.tinymediamanager.TinyMediaManager:349 - Using MediaInfoLib - v0.7.69
2014-06-30 21:52:43,698 INFO  [headless] org.tinymediamanager.TinyMediaManager:361 - initialize database
2014-06-30 21:52:44,062 DEBUG [headless] org.tinymediamanager.TinyMediaManager:363 - database opened
2014-06-30 21:52:44,120 INFO  [headless] o.tinymediamanager.core.movie.MovieList:286 - found 0 movies in database
2014-06-30 21:52:44,150 INFO  [headless] o.tinymediamanager.core.movie.MovieList:329 - found 0 movieSets in database
2014-06-30 21:52:44,151 INFO  [headless] o.t.core.tvshow.TvShowList:203 - found 0 tv shows in database
2014-06-30 21:52:44,155 INFO  [headless] org.tinymediamanager.TinyMediaManager:678 - Commandline - updating movies...
2014-06-30 21:52:44,159 INFO  [SwingWorker-pool-2-thread-1] o.t.c.m.tasks.MovieUpdateDatasourceTask:185 - Done updating datasource :) - took
2014-06-30 21:52:44,159 INFO  [headless] org.tinymediamanager.TinyMediaManager:697 - Commandline - scraping new movies...
2014-06-30 21:52:44,160 INFO  [headless] org.tinymediamanager.TinyMediaManager:711 - No new movies found to scrape - skipping
2014-06-30 21:52:44,160 INFO  [headless] org.tinymediamanager.TinyMediaManager:716 - Commandline - rename & cleanup new movies...
2014-06-30 21:52:44,160 INFO  [headless] org.tinymediamanager.TinyMediaManager:751 - Commandline - updating TvShows and episodes...
2014-06-30 21:52:44,161 INFO  [SwingWorker-pool-2-thread-2] o.t.c.t.tasks.TvShowUpdateDatasourceTask:131 - Done updating datasource :) - took
2014-06-30 21:52:44,161 INFO  [headless] org.tinymediamanager.TinyMediaManager:771 - Commandline - scraping new TvShows...
2014-06-30 21:52:44,162 INFO  [headless] org.tinymediamanager.TinyMediaManager:781 - No new TvShows/episodes found to scrape - skipping
2014-06-30 21:52:44,162 INFO  [headless] org.tinymediamanager.TinyMediaManager:786 - Commandline - rename & cleanup new episodes...
2014-06-30 21:52:44,162 INFO  [headless] org.tinymediamanager.TinyMediaManager:450 - bye bye
I guess, you first need to CD into that dir, and then execute the EXE, not to execute with complete path..
Yay.. we should fix that... i've sent me a reminder Big Grin
ok, will work with upcoming 2.6 Smile
