Full Version: Movie library on home screen
I was wondering why XBMC has never set up to handle Movies from the home screen like it does the TV shows.
or am I just not finding how to set it up! I have searched the forums over from General to Skins and have found nothing I can only find a why to set it to link to my Library, I would Like to show my Un Watched movies on my home page or maybe just a few of them, is this possible ?Undecided and if so how? Blush
thanks
George
Gotham 13.1
I think you need to look at something called Skin Widgets. The skin you are using has to support it (Confluence doesn't by default, there are Confluence mods that do). If you use that and the skin has set things up properly, you should be able to get a list of recently imported, unwatched movies on your home screen.
Correct, many skins support this.
Thanks I will look into the mods
