Full Version: Find build depends when building with many core elements disabled
We are exploring the option to build a headless xbmc package for Synology users.
Because there are some exotic CPU architectures out there I want to limit buliding the dependencies to what is strictly necessary to build xbmc with the following configuration:
./configure \
  --enable-shared-lib \
  --enable-nfs \
  --disable-debug \
  --disable-vdpau \
  --disable-vaapi \
  --disable-crystalhd \
  --disable-vdadecoder \
  --disable-vtbdecoder \
  --disable-openmax \
  --disable-joystick \
  --disable-xrandr \
  --disable-rsxs \
  --disable-projectm \
  --disable-rtmp \
  --disable-airplay \
  --disable-airtunes \
  --disable-dvdcss \
  --disable-optical-drive \
  --disable-libbluray \
  --disable-libusb \
  --disable-libcec \
  --disable-libmp3lame \
  --disable-libcap \
  --disable-ssh \
  --disable-udev \
  --disable-libvorbisenc \
  --disable-asap-codec \
  --disable-afpclient \
  --disable-goom \
  --disable-avahi \
  --disable-non-free \
  --disable-upnp \
  --disable-alsa
Is there any way to determine the list of dependancies?
while not strictly kosher, you can read the list in my fork without much effort:
https://github.com/notspiff/xbmc-cmake/b...ts.txt#L83
(2014-07-01, 10:35)ironic_monkey Wrote: [ -> ]while not strictly kosher, you can read the list in my fork without much effort:
On first sight that looks totally different than the deps I see being used for this headless xbmc Dockfile:
https://github.com/wernerb/docker-xbmc-s...erfile#L61
ah stupid me. yes, i have put a shitload of stuff into addons so their deps are not reflected in the core deps. so this wont help you much.
I'd use the full deps list from https://github.com/xbmc/xbmc-packaging/b...fo.unified and subtract the ones you disable. It might still render you a few superfluous deps, but better then nothing Wink
(2014-07-01, 16:52)wsnipex Wrote: [ -> ]I'd use the full deps list from https://github.com/xbmc/xbmc-packaging/b...fo.unified and subtract the ones you disable. It might still render you a few superfluous deps, but better then nothing Wink
Thanks wsnipex. I was looking in the configure.in file and wonder if we can disable more stuff before building (gtest, sdl, gles, gl, texturepacker, x11, ffmpeg)?
I guess you need ffmpeg for upnp
