Full Version: Copying a folder into Userdata
Hi everyone.
I have been trying to learn how to build xbmc for a few months now and I have implemented a few patches that I have found on the web and got them to work but there is something I have been stuck on now for a week and I have googled non stop but can't seem to find examples or answers to what I am trying to achieve.
I have added in a multi language patch for the onscreen keyboard and I want to be able to copy the entire folder over to the Userdata folder.
In application.cpp I have found the following.
static void CopyUserDataIfNeeded(const CStdString &strPath, const CStdString &file)
  CStdString destPath = URIUtils::AddFileToFolder(strPath, file);
  if (!CFile::Exists(destPath))
    // need to copy it across
    CStdString srcPath = URIUtils::AddFileToFolder("special://xbmc/userdata/", file);
    CFile::Cache(srcPath, destPath);
// copy required files
  CopyUserDataIfNeeded("special://masterprofile/", "RssFeeds.xml");
  CopyUserDataIfNeeded("special://masterprofile/", "favourites.xml");
  CopyUserDataIfNeeded("special://masterprofile/", "Lircmap.xml");
If I add my files one at a time to the end of this then they will work, eg.
CopyUserDataIfNeeded("special://masterprofile/", "/languagekeys/english.xml");
CopyUserDataIfNeeded("special://masterprofile/", "/languagekeys/french.xml");
CopyUserDataIfNeeded("special://masterprofile/", "/languagekeys/russian.xml");
But I want to be able to copy over the entire "languagekeys" folder in one go as there are loads of files in there and they will be changing often.
I think I need a URIUtils::GetDirectory function but I have no idea how I would implement this.
If any of you kind people could please point me in the right direction or tell me what code I need that would be brilliant. Also can anyone suggest any good reading material to help me understand the coding better.
Thank you very much.
Wendy
