(2014-07-03, 05:02)krustyreturns Wrote: [ -> ]There's your problem, you need version 2.95 to enable forced radio. You can get it on our download page.
I thought that is what I had until you asked me for the info.
Installed 2.95, reset the PVR database and restarted XBMC...
Now, the channels show up in 'Radio Channels', but will not play...says 'No video data found on this channel'.
I checked he savedfordebug folder...found the file...it plays fine in WMP.
I uploaded the file to your shared drive.
Excerpt from log:
2014/07/02 22:12:16.391 Received client request: Win7Up|OpenLiveStream|32145|1|909|Music Choice: Hip-Hop Classics
2014/07/02 22:12:16.398 OpenLiveStream> -----------------start------------------------
2014/07/02 22:12:16.398 OpenLiveStream> client: Win7Up requesting live stream
2014/07/02 22:12:16.408 StreamProc> live-tv started
2014/07/02 22:12:16.424 SetChannel> Attempt: 0, Tuner: HDHomeRun Prime Tuner 131AA596-2 / 38e8dcd7-bdc3-43e3-bd17-798844d8fcdb
2014/07/02 22:12:16.425 SetChannel> > Digital: True
2014/07/02 22:12:16.425 SetChannel> > Encrypted: False
2014/07/02 22:12:16.426 SetChannel> > RecorderInfo found: True
2014/07/02 22:12:16.426 SetChannel> > Recorder Content Protection: PROT_COPY_FREE
2014/07/02 22:12:16.434 SetChannel > busy: False, client: none
2014/07/02 22:12:16.435 SetChannel> > tuner is available => stopping search
2014/07/02 22:12:16.437 SetChannel> Recorder acquired: True
2014/07/02 22:12:16.441 SetChannel> TuneRequest set
2014/07/02 22:12:16.479 StreamProc> wtv recording started in 0.07 sec
2014/07/02 22:12:16.479 StreamProc> stream output file: LiveTV_Win7Up_Digital Cable_909_2014_07_02_22_12_16.ts
2014/07/02 22:12:16.480 StreamProc> started remux thread: 'MC07-909: 32145'
2014/07/02 22:12:16.517 Remux::FindDescriptors> Scanning wtv for streams...
2014/07/02 22:12:18.783 Parse> Guid: 0 took 2.19 sec, it was attempted 1060 times
2014/07/02 22:12:18.805 Parse> Next 4 Guids: 0.02 sec, 0.00 sec, 0.00 sec, 0.00 sec,
2014/07/02 22:12:21.021 Parse> Last number of attempts for Guid header was large: 1072
2014/07/02 22:12:23.260 Parse> Last number of attempts for Guid header was large: 1066
2014/07/02 22:12:25.493 Parse> Last number of attempts for Guid header was large: 1083
2014/07/02 22:12:26.487 WaitForTsFile> timeout reached, throwing exception
2014/07/02 22:12:26.488 StreamProc> process start error: Stream file 'ts' does not exist (likely no data was found to remux), timeout: 10,000 ms reached. calling Close()
2014/07/02 22:12:26.498 Remux::Stop> caller is requesting to stop remux thread before descriptors are found
2014/07/02 22:12:26.498 Remux::Stop> stop remux requested
2014/07/02 22:12:26.501 WtvToPesDemuxer:
arse> Guid header detects stream end
2014/07/02 22:12:26.501 Parse> Descriptor pass done, using 236 guids in 7.70 sec
2014/07/02 22:12:26.501 Parse> Total Descriptor parse time: 9.91 sec
2014/07/02 22:12:26.501 Pass 'Descriptor':
2014/07/02 22:12:26.501 > WtvToPesDemuxer:
arse> total guid headers processed: 236
arse> total data packets processed: 46
2014/07/02 22:12:26.508 Remux::FindDescriptors> wtv scanned (10.00 sec), Streams found:
2014/07/02 22:12:26.510 > Audio: ID:31 (und) ac3 2.0 48000 Hz 192 kb/s
2014/07/02 22:12:26.512 > Video: ID:32 mpeg2video MP-ML 704x480p fps: 30000/1001 AR: 1:1
2014/07/02 22:12:26.513 Remux::FindDescriptors> Removing 'ID:32 mpeg2video MP-ML 704x480p fps: 30000/1001 AR: 1:1' as AudioOnly is specified
2014/07/02 22:12:26.513 Remux::FindDescriptors> Output streams:
2014/07/02 22:12:26.513 > Audio: ID:31 (und) ac3 2.0 48000 Hz 192 kb/s
2014/07/02 22:12:26.513 Remux::FindDescriptors> warning: no video streams to remux
2014/07/02 22:12:28.504 Parse> Exception:
2014/07/02 22:12:28.505 Parse> Pass: mux2ts
2014/07/02 22:12:28.505 Parse> Guid count: 300
2014/07/02 22:12:28.505 Parse> Header:
2014/07/02 22:12:28.505 Parse> re-throwing exception
2014/07/02 22:12:28.508 Remux> error: System.Threading.ThreadAbortException: Thread was being aborted.
at Remuxer.demux.microsoft.WtvToPesDemuxer.parse(JobStreamI stream, MuxManager muxManager)
at Remuxer.muxer.MuxManager.mux(JobStreamI stream)
at Remuxer.Remux.Start(String clientName, String outFullFileName)
2014/07/02 22:12:28.512 Remux> requesting D:\Recorded TV\TempSWMC\LiveTV_Win7Up_Digital Cable_909_2014_07_02_22_12_16.wtv be saved from deletion
2014/07/02 22:12:28.513 Remux> ENDED, >>>>>>>>>> Run Time: 0.03 min <<<<<<<<<<
2014/07/02 22:12:28.514 StreamProc::CloseRemux> warning: remux job did not end smoothly
2014/07/02 22:12:28.514 StreamProc::Close> remux stopped successfully
2014/07/02 22:12:28.572 DeleteTS> ts file size: 229,376
2014/07/02 22:12:28.573 StreamProc::Close> ts file deleted: D:\Recorded TV\TempSWMC\LiveTV_Win7Up_Digital Cable_909_2014_07_02_22_12_16.ts
2014/07/02 22:12:28.574 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2014/07/02 22:12:28.614 StreamProc::Close> wtv closed successfully
2014/07/02 22:12:28.664 StreamProc::Close> wtv file size: 786,432 (0xC0000)
2014/07/02 22:12:28.665 StreamProc::Close> WTV FILE SAVED FOR DEBUG: D:\Recorded TV\TempSWMC\LiveTV_Win7Up_Digital Cable_909_2014_07_02_22_12_16.wtv
2014/07/02 22:12:28.665 StreamProc::Close> closed in 2.17 sec
2014/07/02 22:12:28.666 OpenLiveStream> error: Stream file 'ts' does not exist (likely no data was found to remux), timeout: 10,000 ms reached.
2014/07/02 22:12:28.666 Finished request OpenLiveStream in 12.28s
2014/07/02 22:12:31.908 Received client request: Win7Up|ClientGoingDown
2014/07/02 22:12:31.908 ClientGoingDown> Client 'Win7Up' disconnecting
2014/07/02 22:12:31.910 Finished request ClientGoingDown in 0.00s
2014/07/02 22:12:35.826 MainWindow::Window_Loaded> not running as service, checking folder status.
2014/07/02 22:12:35.826 MainWindow::Window_Loaded> Done
2014/07/02 22:12:38.543 Client: '192.168.67.141' addon Version: 0.2.96, Client OS:
2014/07/02 22:12:38.544 Client: '192.168.67.141' running remotely: True
2014/07/02 22:12:38.548 Received client request: 192.168.67.141|GetTimers
2014/07/02 22:12:38.586 Finished request GetTimers in 0.04s
2014/07/02 22:12:38.628 Received client request: 192.168.67.141|GetRecordings
2014/07/02 22:12:38.642 GetRecordings> Total process time 0.01 sec
2014/07/02 22:12:38.642 GetRecordings> Completed for client 192.168.67.141, results:
2014/07/02 22:12:38.642 GetRecordings> Transfered: RecTV folder files: 0, watched files: 0
2014/07/02 22:12:38.642 GetRecordings> Ignored: local files: 0, temp files: 8
2014/07/02 22:12:38.642 GetRecordings> Weird files: no program: 0, no channel: 0, orphaned: 0
2014/07/02 22:12:38.642 GetRecordings> Misc: content protected: 0, icons: 0, instantRec: 0, metaDataReads: 0
2014/07/02 22:12:38.642 GetRecordings> Invalid StartTimes: 0
2014/07/02 22:12:38.642 Finished request GetRecordings in 0.01s
