Full Version: Problem with showing XBMC in second screen through HDMI
Hello to all.
I have an issue and i just cannot figure out a solution. Huh
I`m a linux user (based on ubuntu 14.04 x64 - Cinnamon ver. 2.3.0 Enviroment - Kernel 3.13.0-30 - Nvidia binary Driver ver. 340.17 ) on an Acer Aspire 6920G (specs: 4Gb Ram ,CPU Intel Core 2 Duo, Nvidia GeForce 9500M GS). I`m running a XBMC version 13.0.
My problem started when my laptop`s screen got broken so i had to connect it through HDMI port to my TVscreen (samsung 40'' LCD HD LE40B550). Laptop`s screen resolution 1366x768 (16:9) and Tvscreen`s resolution 1680x1050 (16:10)
I have made my Tvscreen my main screen since i cannot use the other screen anymore and everything runs smoothly except the XBMC. What ever i do i cannot make it work...xbmc keeps running on lapotop`s screen and i cannot make it run in TVscreen. Since now i have only managed to run xbmc in windowed mode in Tvscreen. When i try to make it full screen it deactivates my TVscreen ,messes up my screen configuration and returns as Fullscreen in laptop`s broken screen.
It`s really frustrating cause then i have to reconfigure everything using a broken screen where little can be seen. I don`t know what other info that i could provide whould make it easier for you people to help me out.
I`m in your disposal if you want anything else.
Thanks in advance.
All i have is the XBMC crashlog
################# LOG FILE ##################
02:14:22 T:140085780924352  NOTICE: special://profile/ is mapped to: special://masterprofile/
02:14:22 T:140085780924352  NOTICE: -----------------------------------------------------------------------
02:14:22 T:140085780924352  NOTICE: Starting XBMC (13.0 Git:Unknown). Platform: x86 Linux 64-bit
02:14:22 T:140085780924352  NOTICE: Using Release XBMC x64 build, compiled May 20 2014 by GCC 4.8.2 for x86 Linux 64-bit 3.13.9
02:14:22 T:140085780924352  NOTICE: Running on Linux 64-bit (Ultimate_Edition (4.2), 3.13.0-29-generic x86_64)
02:14:22 T:140085780924352  NOTICE: Host CPU: Intel(R) Core(TM)2 Duo CPU T8100 @ 2.10GHz, 2 cores available
02:14:22 T:140085780924352  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
02:14:22 T:140085780924352  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
02:14:22 T:140085780924352  NOTICE: special://masterprofile/ is mapped to: /home/me/.xbmc/userdata
02:14:22 T:140085780924352  NOTICE: special://home/ is mapped to: /home/me/.xbmc
02:14:22 T:140085780924352  NOTICE: special://temp/ is mapped to: /home/me/.xbmc/temp
02:14:22 T:140085780924352  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
02:14:22 T:140085780924352  NOTICE: Local hostname: Me-Aspire-6920
02:14:22 T:140085780924352  NOTICE: Log File is located: /home/me/.xbmc/temp/xbmc.log
02:14:22 T:140085780924352  NOTICE: load settings...
02:14:23 T:140085780924352  NOTICE: Found 1 Lists of Devices
02:14:23 T:140085780924352  NOTICE: Enumerated PULSE devices:
02:14:23 T:140085780924352  NOTICE:     Device 1
02:14:23 T:140085780924352  NOTICE:         m_deviceName      : Default
02:14:23 T:140085780924352  NOTICE:         m_displayName     : Default
02:14:23 T:140085780924352  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
02:14:23 T:140085780924352  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
02:14:23 T:140085780924352  NOTICE:         m_channels        : FL,FR
02:14:23 T:140085780924352  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
02:14:23 T:140085780924352  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S16NE,AE_FMT_S24LE3,AE_FMT_S24BE3,AE_FMT_S24NE3,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S24NE4,AE_FMT_S32BE,AE_FMT_S32LE,AE_FMT_S32NE,AE_FMT_FLOAT
02:14:23 T:140085780924352  NOTICE:     Device 2
02:14:23 T:140085780924352  NOTICE:         m_deviceName      : alsa_output.pci-0000_00_1b.0.analog-stereo
02:14:23 T:140085780924352  NOTICE:         m_displayName     : Built-in Audio Analog Stereo
02:14:23 T:140085780924352  NOTICE:         m_displayNameExtra: Analog Output (PULSEAUDIO)
02:14:23 T:140085780924352  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
02:14:23 T:140085780924352  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
02:14:23 T:140085780924352  NOTICE: Default DVD Player: dvdplayer
02:14:23 T:140085780924352  NOTICE: Default Video Player: dvdplayer
02:14:23 T:140085780924352  NOTICE: Default Audio Player: paplayer
02:14:23 T:140085780924352  NOTICE: Disabled debug logging due to GUI setting. Level 0.
02:14:23 T:140085780924352  NOTICE: Log level changed to 0
02:14:23 T:140085780924352  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
02:14:23 T:140085780924352  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
02:14:23 T:140085780924352  NOTICE: Loaded playercorefactory configuration
02:14:23 T:140085780924352  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
02:14:23 T:140085780924352  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
02:14:23 T:140085780924352  NOTICE: LoadFromXML - unable to load:/home/katerina/.xbmc/userdata/wakeonlan.xml
02:14:23 T:140085325567744  NOTICE: Thread ActiveAE start, auto delete: false
02:14:23 T:140085392680704  NOTICE: Thread AESink start, auto delete: false
02:14:23 T:140085780924352  NOTICE: Running database version Addons16
02:14:23 T:140085780924352  NOTICE: ADDONS: Using repository repository.xbmc.org
02:14:23 T:140085366580992  NOTICE: Thread PeripBusCEC start, auto delete: false
02:14:23 T:140085358188288  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
02:14:23 T:140085780924352  NOTICE: Setup SDL
02:14:23 T:140085780924352  NOTICE: Checking resolution 49
02:14:23 T:140085780924352  NOTICE: Using visual 0x205
02:14:24 T:140085780924352   ERROR: GLX: Same window as before, refreshing context
02:14:24 T:140085780924352  NOTICE: GL_VENDOR = nouveau
02:14:24 T:140085780924352  NOTICE: GL_RENDERER = Gallium 0.4 on NV84
02:14:24 T:140085780924352  NOTICE: GL_VERSION = 3.0 Mesa 10.3.0-devel
02:14:24 T:140085780924352  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
02:14:24 T:140085780924352  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_stencil_texturing GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_multi_bind GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix
02:14:24 T:140085780924352  NOTICE: No Joystick name specified, loading default map
02:14:24 T:140085780924352  NOTICE: Previous line repeats 35 times.
02:14:24 T:140085780924352  NOTICE: Running database version Addons16
02:14:24 T:140085780924352  NOTICE: Running database version ViewModes6
02:14:24 T:140085780924352  NOTICE: Running database version Textures13
02:14:24 T:140085780924352  NOTICE: Running database version MyMusic46
02:14:24 T:140085780924352  NOTICE: Running database version MyVideos78
02:14:24 T:140085780924352  NOTICE: Running database version TV22
02:14:24 T:140085780924352  NOTICE: Running database version Epg7
02:14:24 T:140085780924352  NOTICE: start dvd mediatype detection
02:14:24 T:140085780924352  NOTICE: initializing playlistplayer
02:14:24 T:140085780924352  NOTICE: DONE initializing playlistplayer
02:14:24 T:140085373716224  NOTICE: Thread DetectDVDMedia start, auto delete: false
02:14:24 T:140085780924352 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
02:14:24 T:140085780924352 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
02:14:24 T:140085780924352  NOTICE: initialize done
02:14:24 T:140085780924352  NOTICE: Running the application...
02:14:24 T:140084703647488  NOTICE: Thread LanguageInvoker start, auto delete: false
02:14:24 T:140084981679872  NOTICE: Previous line repeats 13 times.
02:14:24 T:140084981679872  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084308174592  NOTICE: Thread JobWorker start, auto delete: true
02:14:24 T:140084939716352  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140085780924352  NOTICE: starting zeroconf publishing
02:14:24 T:140085780924352  NOTICE: ES: Starting event server
02:14:24 T:140084291389184  NOTICE: Thread JobWorker start, auto delete: true
02:14:24 T:140084274603776  NOTICE: Thread TCPServer start, auto delete: false
02:14:24 T:140084282996480  NOTICE: Thread EventServer start, auto delete: false
02:14:24 T:140084282996480  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
02:14:24 T:140084282996480  NOTICE: UDP: Listening on port 9777
02:14:24 T:140085325645568  NOTICE: Thread RSSReader start, auto delete: false
02:14:24 T:140084670076672  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084720432896  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084695254784  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084703647488  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084931323648  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084686862080  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084956501760  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084973287168  NOTICE: -->Python Interpreter Initialized<--
02:14:24 T:140084964894464  NOTICE: -->Python Interpreter Initialized<--
02:14:25 T:140084678469376  NOTICE: -->Python Interpreter Initialized<--
02:14:25 T:140084973287168  NOTICE: service.libraryautoupdate-0.9.2 : Update Library Service starting...
02:14:25 T:140084973287168  NOTICE: service.libraryautoupdate-0.9.2 : update timers
02:14:25 T:140084973287168  NOTICE: service.libraryautoupdate-0.9.2 : Creating timer for Video Library
02:14:25 T:140084948109056  NOTICE: -->Python Interpreter Initialized<--
02:14:25 T:140084712040192  NOTICE: -->Python Interpreter Initialized<--
02:14:25 T:140084033459968  NOTICE: Thread AlarmClock start, auto delete: false
02:14:25 T:140084712040192  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.10)
02:14:25 T:140084948109056  NOTICE: script.advanced.wol: Starting WOL script
02:14:25 T:140084948109056  NOTICE: script.advanced.wol: WakeOnLan signal sent to MAC-Address 00:25:11:c4:fb:8a
02:14:25 T:140084678469376  NOTICE:  StorageServer Module loaded RUN
02:14:25 T:140084678469376  NOTICE: StorageClient-2.5.4 Starting server
02:14:25 T:140084939716352  NOTICE: plugin.dbmc: DropboxSynchronizer started
02:14:25 T:140084712040192  NOTICE: script.tv.show.next.aired: ### no prior data found
02:14:25 T:140084695254784  NOTICE: XBMB3C InProgressUpdaterThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C RecentInfoUpdaterThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C RandomInfoUpdaterThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C NextUpUpdaterThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C WebSocketThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C LoadMenuOptionsThread -> Log Level:0
02:14:25 T:140084000003840  NOTICE: XBMB3C LoadMenuOptionsThread -> LoadMenuOptionsThread -> Error Parsing favourites.xml : [Errno 2] No such file or directory: '/home/katerina/.xbmc/userdata/favourites.xml'
02:14:25 T:140084695254784  NOTICE: XBMB3C BackgroundRotationThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C ThemeMusicThread -> Log Level:0
02:14:25 T:140084695254784  NOTICE: XBMB3C InfoUpdaterThread -> Log Level:0
02:14:25 T:140083898341120  NOTICE: XBMB3 -> HTTP Image Proxy Server Starting
02:14:25 T:140084695254784  NOTICE: XBMB3C Service -> starting monitor service
02:14:26 T:140084948109056  NOTICE: script.advanced.wol: Error No.: 1 / Error Msg.: Operation not permitted - Note that ICMP messages can only be sent from processes running as root.
02:14:26 T:140084948109056  NOTICE: script.advanced.wol: Closing WOL script
02:14:26 T:140084964894464  NOTICE: XBMB3C InProgressUpdaterThread -> urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:26 T:140084956501760  NOTICE: XBMB3C RecentInfoUpdaterThread -> updateRecent urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:26 T:140084016789248  NOTICE: XBMB3C NextUpUpdaterThread -> urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:26 T:140084008396544  NOTICE: XBMB3C WebSocketThread -> WebSocketThread getWebSocketPort urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/System/Info?format=json)
02:14:26 T:140083991611136  NOTICE: XBMB3C BackgroundRotationThread -> urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:26 T:140083906733824  NOTICE: XBMB3C InfoUpdaterThread -> urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:27 T:140084712040192  NOTICE: script.tv.show.next.aired: ### starting data update
02:14:27 T:140083991611136  NOTICE: XBMB3C BackgroundRotationThread -> updateTypeArtLinks urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:14:27 T:140083991611136  NOTICE: TIMEDIFF01 : 0.982572078705
02:14:27 T:140083991611136  NOTICE: TIMEDIFF02 : 0.970301866531
02:14:27 T:140083991611136  NOTICE: BackgroundRotationThread Update Links Failed
02:14:27 T:140083991611136  NOTICE: Server details string : () ()
02:14:34 T:140084008396544  NOTICE: Previous line repeats 6 times.
02:14:34 T:140084008396544  NOTICE: Thread BackgroundLoader start, auto delete: false
02:14:34 T:140083991611136  NOTICE: Server details string : () ()
02:14:35 T:140084939716352   ERROR: plugin.dbmc: DropboxSynchronizer could not connect to dropbox: No token (access code)
02:14:35 T:140084008396544  NOTICE: Thread BackgroundLoader start, auto delete: false
02:14:35 T:140083991611136  NOTICE: Server details string : () ()
02:14:38 T:140084008396544  NOTICE: Previous line repeats 2 times.
02:14:38 T:140084008396544  NOTICE: Thread LanguageInvoker start, auto delete: false
02:14:38 T:140084008396544  NOTICE: -->Python Interpreter Initialized<--
02:14:38 T:140083991611136  NOTICE: Server details string : () ()
02:14:39 T:140084008396544  NOTICE: [xbmcswift2] Request for "/" matches rule for function "show_root_menu"
02:14:39 T:140084948109056  NOTICE: Thread BackgroundLoader start, auto delete: false
02:14:39 T:140083991611136  NOTICE: Server details string : () ()
02:14:40 T:140084008396544  NOTICE: Thread LanguageInvoker start, auto delete: false
02:14:40 T:140084008396544  NOTICE: -->Python Interpreter Initialized<--
02:14:40 T:140084008396544  NOTICE: [xbmcswift2] Request for "/movies/most_watched/" matches rule for function "show_movies"
02:14:40 T:140084008396544  NOTICE: XBMC Add-on HD-Trailers.net v1.1.0 scraper: __get_tree opening url: http://www.hd-trailers.net/most-watched/
02:14:40 T:140083991611136  NOTICE: Server details string : () ()
02:14:42 T:140084008396544  NOTICE: Previous line repeats 1 times.
02:14:42 T:140084008396544  NOTICE: XBMC Add-on HD-Trailers.net v1.1.0 scraper: __get_tree got 26259 bytes
02:14:42 T:140084948109056  NOTICE: Thread BackgroundLoader start, auto delete: false
02:14:42 T:140083991611136  NOTICE: Server details string : () ()
02:14:42 T:140084008396544  NOTICE: Thread JobWorker start, auto delete: true
02:14:43 T:140083991611136  NOTICE: Previous line repeats 1 times.
02:14:43 T:140083991611136  NOTICE: Server details string : () ()
02:14:45 T:140083885983488  NOTICE: Previous line repeats 1 times.
02:14:45 T:140083885983488  NOTICE: Thread LanguageInvoker start, auto delete: false
02:14:45 T:140083885983488  NOTICE: -->Python Interpreter Initialized<--
02:14:45 T:140083885983488  NOTICE: [xbmcswift2] Request for "/videos/dawn-of-the-planet-of-the-apes/" matches rule for function "show_videos"
02:14:45 T:140083885983488  NOTICE: XBMC Add-on HD-Trailers.net v1.1.0 scraper: __get_tree opening url: http://www.hd-trailers.net/movie/dawn-of-the-planet-of-the-apes
02:14:45 T:140083991611136  NOTICE: Server details string : () ()
02:14:46 T:140083885983488  NOTICE: XBMC Add-on HD-Trailers.net v1.1.0 scraper: __get_tree got 63311 bytes
02:14:46 T:140083885983488  NOTICE: XBMC Add-on HD-Trailers.net v1.1.0 scraper: Skipping: dawn-of-the-planet-of-the-apes - http://avideos.5min.com/564/5180564/518056379_2.mp4
02:14:46 T:140083991611136  NOTICE: Server details string : () ()
02:14:47 T:140083885983488  NOTICE: Thread BackgroundLoader start, auto delete: false
02:14:47 T:140083991611136  NOTICE: Server details string : () ()
02:14:55 T:140083885983488  NOTICE: Previous line repeats 7 times.
02:14:55 T:140083885983488  NOTICE: Thread LanguageInvoker start, auto delete: false
02:14:55 T:140083885983488  NOTICE: -->Python Interpreter Initialized<--
02:14:55 T:140083991611136  NOTICE: Server details string : () ()
02:14:59 T:140083991611136  NOTICE: Previous line repeats 3 times.
02:14:59 T:140083991611136  NOTICE: XBMB3C BackgroundRotationThread -> urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:15:00 T:140083991611136  NOTICE: XBMB3C BackgroundRotationThread -> updateTypeArtLinks urlopen : [Errno socket error] [Errno -2] Name or service not known (http://<none>:8096/mediabrowser/Users?format=json)
02:15:00 T:140083991611136  NOTICE: TIMEDIFF01 : 0.87446308136
02:15:00 T:140083991611136  NOTICE: TIMEDIFF02 : 1.00651097298
02:15:00 T:140083991611136  NOTICE: BackgroundRotationThread Update Links Failed
02:15:01 T:140083885983488  NOTICE: Thread LanguageInvoker start, auto delete: false
02:15:01 T:140083885983488  NOTICE: -->Python Interpreter Initialized<--
02:15:01 T:140083885983488  NOTICE: [xbmcswift2] Request for "/video/hd-trailers.net/http%3A%2F%2Fvideos.hd-trailers.net%2FDawn_Of_The_Planet_Of_The_Apes_2014_Trailer_C_International_5.1-720p-HDTN.mp4" matches rule for function "play_video"
02:15:01 T:140083885983488  NOTICE: [plugin.video.hdtrailers_net] Using URL: http://videos.hd-trailers.net/Dawn_Of_The_Planet_Of_The_Apes_2014_Trailer_C_International_5.1-720p-HDTN.mp4
02:15:01 T:140083991611136  NOTICE: Server details string : () ()
02:15:02 T:140085780924352  NOTICE: DVDPlayer: Opening: http://videos.hd-trailers.net/Dawn_Of_The_Planet_Of_The_Apes_2014_Trailer_C_International_5.1-720p-HDTN.mp4
02:15:02 T:140085780924352 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
02:15:02 T:140083877328640  NOTICE: Thread DVDPlayer start, auto delete: false
02:15:02 T:140083877328640  NOTICE: Creating InputStream
02:15:02 T:140083991611136  NOTICE: Server details string : () ()
02:15:03 T:140083877328640  NOTICE: Creating Demuxer
02:15:03 T:140083885983488  NOTICE: Thread FileCache start, auto delete: false
02:15:03 T:140083991611136  NOTICE: Server details string : () ()
02:15:03 T:140083877328640  NOTICE: Opening video stream: 0 source: 256
02:15:03 T:140083877328640  NOTICE: Creating video codec with codec id: 28
02:15:03 T:140083877328640  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
02:15:03 T:140083877328640  NOTICE: Creating video thread
02:15:03 T:140083839039232  NOTICE: Thread DVDPlayerVideo start, auto delete: false
02:15:03 T:140083877328640  NOTICE: Opening audio stream: 1 source: 256
02:15:03 T:140083877328640  NOTICE: Finding audio codec for: 86019
02:15:03 T:140083877328640  NOTICE: Creating audio thread
02:15:03 T:140083839039232  NOTICE: running thread: video_thread
02:15:03 T:140083830646528  NOTICE: Thread DVDPlayerAudio start, auto delete: false
02:15:03 T:140083830646528  NOTICE: running thread: CDVDPlayerAudio::Process()
02:15:03 T:140083830646528  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
02:15:03 T:140083839039232   ERROR: VAAPI - unable to initialize display -1 - unknown libva error
02:15:03 T:140083839039232  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating VDPAU(1280x692)
02:15:03 T:140083839039232  NOTICE: VDPAU::CreateContext - creating decoder context
02:15:03 T:140083839039232  NOTICE: vdp_device = 0x00000000 vdp_st = 0x00000001
02:15:03 T:140083839039232   ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1.  Falling back.
02:15:03 T:140083839039232  NOTICE:  (VDPAU) Close
02:15:03 T:140083839039232  NOTICE: VDPAU::Close - closing decoder context
############### END LOG FILE ################
PS: If i have posted something in the wrong way please notify me and i ll try to correct it .
Several things spring to mind !
1) Don't paste logs inline. Use a site like pastebin or xbmclogs and paste a link to the log here Wink
2) That logfile shows XBMC using the nouveau driver, not the nVidia driver
3) That isn't an official build of XBMC
So, how to fix your issue ?
If you uninstall your current version, remove whatever source you got it from and add this PPA https://launchpad.net/~aap/+archive/xbmc...ernetmenta and re-install from there then that version will have true multi-monitor support.
That means you can choose to have it always display on the external HDMI port. It may be difficult to navigate XBMC to change it to that setting though if it starts on your broken display. If you can turn off the internal display (most laptops have this option) then that may help.
Thank you for your time and sorry for the the log file.
Well i`ve seen that too (about my nvidia card) but i don`t get it . Here is a screenshot from my xbmc Screenshot that shows xbmc seeing my Nvidia driver 340.17.
I have uninstalled xbmc, purged it, cleaned my Repos and reinstalled following the directions of this Linux Guide.
And here is the XBMC Log File .
Needless to say the problem persists!
OK, that second logfile shows the correct nVidia driver Smile
Did you install from the team-xbmc repository as per the guide, or did you install from the ppa I linked you to ? The team-xbmc repo does not contain a version of xbmc that has proper multiple monitor support as the code is broken.
