2014-07-04, 09:43
Good Morning All,
I'm using:
Synology Nas - for mysql,
raspberry pi - mod b - Raspbmc - running 12.3
windows 7 - running 12.3
samsung s4 - running 12.3
Its all setup sharing the same mysql database, the sources.xml, profiles.xml and mediasources.xml are all shared from the nas.
each has the same advancedsettings.xml, and i know this bit works as the sources and mediasources are all correct on all three devices without me setting them up on the raspberrypi and s4 (i used my windows install to set it all up).
The problem i have is this:.
The pi runs 24/7.
When i download a new video, i put it in the appropriate folder, and run xbmc on the pc. It picks it up, tags it gets artwork etc no problems.
The pi and s4 however need a library update to pick up the new video. Is this how shared works? i was hoping that by updating the lib in one place, it would automatically appear in the rest.
I'm using:
The pi runs 24/7.
