Full Version: help needed from skinner
hey there
so I made my first view layout its far from fininshed but its the basic layout minus animations and so on... The layout is from MB Neo theme
I couldent really find any info in the wikki atleast not any I can understand yet (but at one point I gues I will) anout how to do offsets like this
I managed to get the offset but I havent made it the correct way meaning I have no control over focus basicly only positioning.
I am hoping one of you skinners will be willing to make a xml the correct way so I can use it to see how it should be done.
I have been over other skin files but they are using varibles split over other xml and a lot of code I cant seperate as of yet.
here is my xml
PHP Code:
<?xml version="1.0" encoding="utf-8"?>
<includes>
    <include name="Banners">
       <!--Overlay-->
      <control type="image">
            <left>0</left>
            <top>0</top>
            <width>1280</width>
            <height>720</height>
             <texture>white.png</texture>
             <visible>Control.IsVisible(900)</visible>
        </control>
              <!--Banners-->
        <control type="group">
            <posy>25</posy>
            <posx>50</posx>
                <onup>900</onup>
                <ondown>900</ondown>
              <!--Banner -3-->
             <posx>-25</posx>
            <posy>10</posy>
            <width>300</width>
            <height>100</height>
            <texture>$INFO[ListItem(-3).Art(banner)]</texture>
            <aspectratio>keep</aspectratio>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(-3).FolderPath)</visible>
        </control>
              <!--Banner -2-->
            <posx>75</posx>
            <posy>100</posy>
            <width>300</width>
           <texture>$INFO[ListItem(-2).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(-2).FolderPath)</visible>
        </control>
              <!--Banner -1-->
            <posx>200</posx>
            <posy>190</posy>
            <width>300</width>
            <texture>$INFO[ListItem(-1).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(-1).FolderPath)</visible>
        </control>
              <!--Banner 0-->
            <posx>170</posx>
            <posy>275</posy>
            <width>400</width>
            <height>110</height>
            <texture>$INFO[ListItem(0).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(0).FolderPath)</visible>
        </control>
              <!--Banner 1-->
            <posx>180</posx>
            <posy>370</posy>
            <width>300</width>
            <texture>$INFO[ListItem(1).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(1).FolderPath)</visible>
        </control>
              <!--Banner 2-->
            <posx>100</posx>
            <posy>460</posy>
            <width>300</width>
            <texture>$INFO[ListItem(2).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(2).FolderPath)</visible>
        </control>
              <!--Banner 3-->
            <posx>0</posx>
            <posy>550</posy>
            <width>300</width>
            <texture>$INFO[ListItem(3).Art(banner)]</texture>
            <visible>!IsEmpty(Container(900).ListItemNoWrap(3).FolderPath)</visible>
        </control>
</control>
        <!--Wraplist-->
        <control type="wraplist" id="900">
            <posx>200</posx>
            <posy>200</posy>
            <width>600</width>
            <height>520</height>
            <onleft>9000</onleft>
            <onright>-</onright>
            <onup>900</onup>
            <pagecontrol>-</pagecontrol>
            <visible>Container.Content(movies) | Container.Content(tvshows)</visible>
            <viewtype label="Banners">list</viewtype>
            <scrolltime tween="quadratic">300</scrolltime>
            <focusposition>3</focusposition>
            <orientation>vertical</orientation>
            <preloaditems>4</preloaditems>
            <itemlayout width="525" height="260">
            </itemlayout>
            <focusedlayout width="525" height="260">
                </focusedlayout>
</control>
            <control type="label">
                <posx>650</posx>
                <posy>570</posy>
                <width>550</width>
                <height>25</height>
                <font>font20</font>
                <textcolor>black</textcolor>
                <shadowcolor>black</shadowcolor>
                <scroll>true</scroll>
                <align>center</align>
                <aligny>center</aligny>
                <label>$INFO[Listitem.Title]</label>
            </control>
                    <control type="textbox">
                    <description>Description Value The Movie</description>
                    <left>600</left>
                    <top>600</top>
                    <width>650</width>
                    <height>80</height>
                    <font>font12</font>
                    <align>justify</align>
                    <label>$INFO[ListItem.Plot]</label>
                    <autoscroll time="2000" delay="3000" repeat="5000">Skin.HasSetting(AutoScroll)</autoscroll>
                </control>
    </include>
</includes>
and download link Download
and here is the layout
rightclick and open in new tab, for some reason I havent learned how to actually show the image
You need to put your controls inside the <itemlayout> and <focusedlayout>.
well that is easier said then done could you give me an example of how to achieve this dumb it down please Wink
removed151214
Have you looked at the skinning wiki - http://wiki.xbmc.org/?title=Wrap_List_Container
But basically, all the controls you use to actually show the item, be them images, labels, etc, are children of the wraplist's <itemlayout> for items that aren't currently focused and <focusedlayout> for the item that is. Your example closes the focusedlayout without any controls, and doesn't have a itemlayout at all.
(2014-07-06, 02:41)Unfledged Wrote: [ -> ]Have you looked at the skinning wiki - http://wiki.xbmc.org/?title=Wrap_List_Container
@Unfledged
I have read the wikki many times,also your link (all i do is read the wikki) Wink I am aware of the itemlayout and focusedlayout functions as you describe, wich normally makes it rather easy to design a list.
but I dont know how to get my image control to the itemlayout and focusedlayout.
I have tried making my image controls into an include and then include em in the layout but that kind of breaks all view and I have to alt+f4 to reset xbmc.
So how do I get them to the itemlayout ?
I hope you understand I mean
For the controls you're using you need to put them inside a grouplist.
http://wiki.xbmc.org/index.php?title=Group_List_Control
Thank you.
I havent tested or tried anything out only read through the Group list control page but it still not obvious how to get the focus layout ?
