Full Version: Banner/Fanart not displaying in Video Nav (solved)
Edit: I removed everything from the library, then added everything back. Re-scanning everything solved the issue. I remembered importing the library from Gotham and having issues with my music lib as well before I re-scanned my music. Sorry.
Hello there!
I'm using the latest nightly build for creating and testing my skin.
Today I tried to work on a view in Video Navigation and realized that banners and fanarts for tv shows/movies are not being displayed.
This only happens in Video Navigation, I have no problems with fanart in Music Navigation.
The same code works very well in Gotham, so my question is: am I the only one having this problem, is it a bug or are the info labels for fanart/banners in the process of being modified?
I think it started happening a few builds back... but I don't know when exactly. Before I start trying build by build I thought I should ask here first.
Is there anyone skinning for Helix who's having the same issue?
Thank you in advance!
Alex
