2014-07-06, 03:20
most have come to this question.
I want to add an extra skip forward or a skip backward but the answer is always no you got 2 skips forward (30s 10m) and 3 skips back (30s 10m 7s), you can tweak these but can't add anymore.
I found a nice trick to get two extra skips, can either be both forward or both back. or one forward and one back. HOW?
you use this ActionIDs
<keyname>analogseekback</keyname>
<keyname>analogseekforward</keyname>
AnalogSeekForward/SeekBack - Variable speed seeking for analog keys (stick or triggers)
These actions where designed for joysticks. but I learnt that you can map these to buttons and they will trigger a seek. BUT they are varaible if you keep them pressed it does a continious seek, not in steps. This initself is an amazing feature that no one knows about. also using analogseek pops up seekbar (top right) and places a llittle marker to see where your seeking (roughly). a better way to seek a movie using "visual" seek
okay but how do I get an extra seek?
I've learnt that if you do a quick press on analogseek it goes +/- 10 minutes and 23 seconds. This is the lowest amount it will seek +/-. (I believe it does it by a certain percentage, so a normal movie will give you roughly 10 minutes seek time)
since this is 10 minutes +- 20 seconds its effectively 10 minutes. so you replace this for "bigseekforward/back" with this. (analogseekback=-10 minutes 23 seconds, analogseekforward=+10 minutes 23 seconds) AND NOW you got two extra slots
not sure if people know this but just because it says BigStepForward does not mean it has to go forward, you can actually change the number to negative in advancesettings and get it to go back and the same applies to BigStepBack.
this way you got two extra skip choices. what do you think? nice little trick.
some might not follow what I have said but these pages might help
http://wiki.xbmc.org/index.php?title=keymap
http://forum.xbmc.org/showthread.php?tid=183475&page=2
let me know if you get stuck
