2014-07-06, 10:21
Hey All,
I have a strange issue that cropped up a few months back. When a TV episode or movie is imported into XMBC via SickBeard and CouchPotato, the FanArt and Thumbnail for that item is not displayed when browsing in FileView. When looking at Library view the item is imported twice, in the case of a TV episode the entire show is imported twice. The details are listed below. I can't find anything in the forums for this specific issue and I have tried everything I can think of to fix it. Any help would be greatly appreciated. Thanks.
- I have multiple Windows 7 machines running XBMC 13.3.
- They are pointed to a ReadyNAS that hosts the media and a MySQL XBMC database utilizing the below identical files.
advancedsettings.xml
sources.xml (sources mapped via SMB)
profiles.xml
- When I delete an affected show from the Library once it still shows up as if it was imported twice.
- After deleting the show twice and re-importing it, the FanArt and Thumbnails are visible in FileView.
- When Sickbeard adds another episode of the re-imported show the FanArt and Thumbnails are once again not visible in FileView.
- I have set the scraper on a show to None then back to completely remove the item from the Library, re-imported and the same effect when a new episode is added.
profiles.xml
