2014-07-06, 18:45
Hi, I have a Himedia Q10 II and XBMC 13.1 on it, quite happy about it even if it is not out of the box ready to use with xbmc Gotham version, anyway, a bit of work get you to know Xbmc better :-)
To play videos, I am using a custom playercorefactory.xml file which is setup to play mkv files with the himedia video external player ( Hardware decoding and bundled with the box ) and it plays well all in 1080P full framerate.
For the streaming videos, I use MXplayer and it works with hardware decoding just fine.
But for Youtube videos with the add-on, I tried several players and none of them works, anyone having success to stream youtube videos to Himedia Q10II or Q5 from Xbmc add-on ?
If yes, which external player do you use ? And ,if possible, can you post a copy/paste of your playercorefactory.xml ?
Here is mine :
Here is mine :
<playercorefactory>
<players>
<!-- HiMedia Player definition -->
<player name="HimediaPlayer" type="ExternalPlayer" audio="false" video="true">
<filename>com.himedia.android.videoplayer</filename>
<hidexbmc>true</hidexbmc>
<playcountminimumtime>120</playcountminimumtime>
</player>
<!-- MXPlayer Free definition -->
<player name="MXPlayerFree" type="ExternalPlayer" audio="false" video="true">
<!-- Android intent -->
<filename>com.mxtech.videoplayer.ad</filename>
<!-- Hide XBMC -->
<!-- After 2 minutes bump the play count of the item in XBMC -->
</player>
<!-- SopCast Player definition -->
<player name="SopCast" type="ExternalPlayer" audio="false" video="true">
<filename>org.sopcast.android</filename>
<!-- Hide XBMC -->
</player>
</players>
<!-- Rules for which external player to use -->
<rules action="prepend">
<!-- <rule filetypes="*.avi" player="HimediaPlayer">
<rule filetypes="*.mkv" player="HimediaPlayer"> -->
<!-- <rule filetypes="flv" player="MXPlayerFree"> -->
<!-- Samba file shares -->
<rule protocols="smb" player="MXPlayerFree" />
<!-- DVD Images -->
<rule dvdimage="true" player="HimediaPlayer"/>
<!-- rtmp Streams (Ice / Navi-x) -->
<rule protocols="rtmp" player="MXPlayerFree"/>
<!-- rtsp Streams (Type of internet stream) -->
<rule protocols="rtsp" player="MXPlayerFree" />
<rule protocols="http" player="MXPlayerFree" />
<!-- SopCast -->
<rule protocols="sop" player="SopCast" />
<!-- Internet streams -- Disabled for now -->
<rule internetstream="true" player="HimediaPlayer" />
<!-- Video files -- Default rule (last to ensure above trigger first -->
<rule video="true" player="HimediaPlayer"/>
</rules>
</playercorefactory>
