Full Version: No atomatic refresh rate adjustment for 24p content
I noticed that since I updated to ubuntu 14.04 the refresh rate does not adjust to 24p/Hz content. For 50Hz for example, it works like a charm.
This has been already shortly discussed a view months ago here:
http://forum.xbmc.org/showthread.php?tid...id=1610492
Are there any fixes available? Or has someone solved the problem?
Would be thankful for a tipp
Or is there a way that I can start a little skirpt everytime I hit play, and manually set the refresh rate using xandr?
Just set xbmc to auto adjust refresh rate to the video playing
Are you using a desktop?
compositing window managers (e.g. compiz on unity) will block refresh rate switching. Try the standalone session for a test.
Thanks, I will try a stand alone session. This means it is purely unity (compiz) related?
Actually, I noticed that even when I set manually in Ubuntu to 24Hz and then start xbmc, the refresh rate is changed again to 60hz. Doesn't this mean that xbmc has "the power" to overvote compiz?
(2014-07-14, 11:43)klingel_one Wrote: [ -> ]Thanks, I will try a stand alone session. This means it is purely unity (compiz) related?
Nope because the compositor owns the display, not the applications.
But how can my described observation be possible?
I tested it several times
a) Try to enable undirected fullscreen videos (ccsm)
b) Don't come back and complain about tearing
We cannot fix unity /composite bugs here. A user that decides towards a compositing manager should know what he / she / it is doing.
