Full Version: Gotham and tvheadend plugin, not supported?
Hi all,
could be I am trying something stupid. I had a xbmcbuntu 12 installation, which I recently upgraded to 13. I have my /home on a different partition, so the upgrade only nuked the system, but I kept all my files and the ~/.xbmc Folder.
The upgrade had the nice side effect that my somewhat esoteric DVB-T stick is now supported by the kernel. Tvheadend works, too.
But.
In System->Settings->Get Addons: No PVR-Addons
Via search: I fin the Tvheadend HTSP-Client, version 1.6.18. Trying to install gives the error "Dependencies not met. Please contact the author".
Now my question: Is that some stale stuff coming from my way of upgrading, or does this indeed not work?
Thanks for your support.
Tom
sudo apt-get install xbmc-pvr-tvheadend-hts
OK, something stupid, as expected :-)
Thanks, works.
