Full Version: Lirc works, XBMC does not
Hi, there. I am running XBMC 13.1 (f2acae7) Gotham on an Intel NUC and XBMCbuntu . Until yet I use the iOS RC software and I am quite happy with that. But when it’s dark I prefer a remote with physical buttons. That’s why I read quit a lot tutorials and documentation about Lirc, XBMC and the involved config files.
Lirc seems to work, but I cannot control XBMC using my RC.
My progress so far:
irw shows the expected output (I named my remote pioneer):
00000000f50a4fb0 00 KEY_UP pioneer
00000000c53a9966 00 KEY_DOWN pioneer
00000000c53a9966 00 KEY_LEFT pioneer
00000000c53a9966 00 KEY_RIGHT pioneer
my xbmc.log knows about my button presses:
21:16:30 T:140603647997888   DEBUG: LIRC: Update - NEW at 674076:00000000f50a4fb0 00 KEY_UP pioneer (KEY_UP)
21:16:30 T:140603647997888   DEBUG: LIRC: Update - NEW at 675019:00000000c53a9966 00 KEY_DOWN pioneer (KEY_DOWN)
21:16:36 T:140603647997888   DEBUG: LIRC: Update - NEW at 680837:00000000c53a9966 00 KEY_LEFT pioneer (KEY_LEFT)
21:16:38 T:140603647997888   DEBUG: LIRC: Update - NEW at 682129:00000000c53a9966 00 KEY_RIGHT pioneer (KEY_RIGHT)
my \~/.xbmc/userdata/Lircmap.xml looks like this:
<lircmap>
<remote device="pioneer">
<power>KEY_POWER</power>
<enter>KEY_ENTER</enter>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<up>KEY_UP</up>
<down>KEY_DOWN</down>
<back>KEY_BACK</back>
<info>KEY_INFO</info>
<play>KEY_PLAY</play>
<pause>KEY_PAUSE</pause>
<stop>KEY_STOP</stop>
<reverse>KEY_REWIND</reverse>
<forward>KEY_FORWARD</forward>
<skipplus>KEY_NEXT</skipplus>
<skipminus>KEY_PREVIOUS/<skipminus>
<menu>KEY_HOME</menu>
</remote>
</lircmap>
my \~/.xbmc/userdata/keymaps/remote.xml looks like this. To keep it simple I only configured left and right. I expect left and right to be working within XBMC's home screen.
<keymap>
  <global>
    <remote>
      <left>Left</left>
      <right>Right</right>
    </remote>
  </global>
</keymap>
Thank you for your hints. If you need more information, I can provide lircd.conf and hardware.conf, too.
<left>Left</left>
Should be (at least in my keymap)
<left>left</left>
<right>right</right>
Also is this a typo here, or actually in your Lircmap.xml ?
Could be upsetting the parsing of the file.
With one look you spotted the problem. Thank you. A tiny slash broke my config!
I spend more than 6 hours to look for the problem.
